Preferred intake manifold 4 Turbo K20
-Just wanted to get some opinions on an intake manifold for a boosted K24 into an EP3 i am doing.
I wanted to see what people were using, such as the Stock K20Z, K24, K20A3, aftermarket? custom, etc
HP goal is mid 500s, Turbo is a 35R, manifold is an Peakboost K series Sidewinder Equal length.
gimme some other options
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 »</TD></TR><TR><TD CLASS="quote">have u looked at the RBC?</TD></TR></TABLE>
i have seen one on an EG/K20 i tuned it had a throttle body plate welded to it with a new 70mm RPM service throttle body, but it was N/A. Last month he wanted to sell it and he said something like 700 dollars, is that a correct number?????
i have seen a few more out there with the throttle bodies in the center of the manifold, pointing downward, any idea?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRVRX »</TD></TR><TR><TD CLASS="quote">Get hold of Bert-O ( Autoway), he sells tons of the RBC manifolds. The adpater plate is fairly cheap or just make one.</TD></TR></TABLE>
haha, good ole bert-o, aint tlaked to him in a few minutes, been a while.
thanks john
thanks john
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HKSuperSi »</TD></TR><TR><TD CLASS="quote">go w/ rbc. its not that expensive. </TD></TR></TABLE>
thanks for the input.
does the RBC have the removable plenum cover on the bottom?
the RBC for a turbo or NA setup will give you stupid topend compared to the stock manifold. i say its the best bang for your buck
everything thing else you have to wait a year to get in line and it will cost you as much as your whole turbo setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">
does the RBC have the removable plenum cover on the bottom?</TD></TR></TABLE>
no, the rbc doesnt have that. The RBC will gain alot over stock manifold, however im going to do a test here in next month or so of RBC vs other intake manifold. Will post results.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T4eg »</TD></TR><TR><TD CLASS="quote">
no, the rbc doesnt have that. The RBC will gain alot over stock manifold, however im going to do a test here in next month or so of RBC vs other intake manifold. Will post results. </TD></TR></TABLE>
great, right now i have the K24 2 piece intake manifold and was looking at it, i see some rooms for imporovements and was gonna bust out the welder and make some stuff for when i finish the swap and see what i can get out of a little custom unit, i figure instead of throwing it away, why not try a couple things with it
great, right now i have the K24 2 piece intake manifold and was looking at it, i see some rooms for imporovements and was gonna bust out the welder and make some stuff for when i finish the swap and see what i can get out of a little custom unit, i figure instead of throwing it away, why not try a couple things with it</TD></TR></TABLE>
Deffinaly worth a shot, here is my graph stock block, IPS KT1s and RBC manifold
https://honda-tech.com/zerothread?id=2157090
AFI looks sick but were keeping it in the EP3 chassis, i dont know if it will clear
ALSO were are going to keep the K24 head, so this promotes yet another issue of running a head flange adapter for the RBC, or a throttle body adapter for the euro intake
kinda havent made up my mind yet
Does the afi manifold runners keep the same angle of the intake port? It doesnt seem like it from the pics, there is a reason why the stock manifold runners are the way they are.
turbomonkeyexpress
25
Feb 20, 2003 02:56 PM
