Gear is blocked out when trying to downshift
Basically it all started a month ago when i replaced my engine mounts in my 1998 GS.
What happens is when im driving normally, from 1st to 2nd is fine, pops in 2nd gear fine.
As soon as I engage to 3rd, or 4th or 5th, and try to downshift to 2nd gear it won't let me, i have to actually push it in hard, feels like a slight grind also when i go in gear. This only happens in 2nd, not 4th (downshifting from 5th)
It goes in, but only if i push it really hard...at whatever speed im at.
So i came to the conclusion that its either the syncro's, or the shift linkage isn't lined up..
I would appreciate it if i could hear your thoughts and advice on this ******* problem, it's pissing the **** outta me.
thanks! lol
Modified by gsteggy at 7:33 PM 11/27/2007
thanks! lol
did not help at all, no
i took off the center console today to check out the shift linkage, but just came to the metal floor under, is there any way to get to the shift linkage?
thanks for your help tho dogginator
Modified by gsteggy at 6:28 PM 11/27/2007
I also am having this same problem in my 1996, in the same gear... Mine seems to go into second a little easier once its had time to warm up, but i am very curious as to the cause.. I have recently changed my fluid with honda mtf, and also noticed no change... i hope its not a syncro
i've never speed shifted this car...so i wouldn't know, nor will i attempt.
tomorrow im gonna look at the linkage...
thanks for the help guys
American.Graffiti
Transmission & Drivetrain
Oct 20, 2008 01:10 PM
