Car is bogging when i give it gas
Old Nov 26, 2007 | 10:00 PM
SupraRXZ's Avatar
Default Car is bogging when i give it gas
first off here are the specs
91 CRX
STOCK HF motor
so when i try to give it some gas it starts to bog, but when i give it light gas its ok, but a little more than light. it starts to bog and sputter
I tried a technic (dont know how to spell) my friend told me, i pulled off one intake mani sensor at a time, test drive and then put it back and pull a different one until you find the problem.
well....I pulled them all and nothing... still happens
so i was wondering if i can get your guy's info
no CEL also
Old Nov 27, 2007 | 12:13 AM
o VALTER o's Avatar
Default Re: Car is bogging when i give it gas (SupraRXZ)
maybe this will help...
https://honda-tech.com/zerothread?id=2039041
i am still having problems...but thankfully my engine light comes on and the problem goes away untill the next time i start the car.
Old Nov 27, 2007 | 12:24 AM
SupraRXZ's Avatar
it sucks, maybe ill check my IACV, but not sure if its that, i'll try fuel pump next
if you figure anything out PM me, ill do the same for you
Old Nov 27, 2007 | 12:42 AM
Suck my DX's Avatar
Default Re: (SupraRXZ)
wow, theres so many things that could cause this....timing,failing components,electrical connections.....any CEL? if not id check timing and due a tune up, inlcuding fuel filter,spark plug wires,dizzy cap and rotor...no need to change plus unless they are REALLY old...the tend to last a while...i doubt they will be fouled out, but it would be a good idea to check.
Old Nov 27, 2007 | 01:08 AM
rd91sib18c5r's Avatar
My car did that and it was the ground for the map sensor, it's on the firewall.
good luck
Old Nov 27, 2007 | 01:18 AM
davens's Avatar
One more possibility:
Clogged cat, or obstructed exhaust in general, would cause this problem...and I don't think it would trigger a CEL.
Old Nov 27, 2007 | 05:49 AM
zachvirus's Avatar
Default Re: (davens)
i used to have this problem also, it was my gas tank.
clogged up with rust.
gl on finding the problem
Old Nov 27, 2007 | 05:53 AM
ltgrazer65's Avatar
i had a similar problem, and it was a ground that didn't have a good connection. it was the one that is on the trans. check that out hope it helps
Old Nov 27, 2007 | 03:14 PM
o VALTER o's Avatar
Default Re: (zachvirus)
i thought about that, figured while i had my gas pump out, i would check for rust. advanced auto parts sells a tank for $125...
Old Nov 27, 2007 | 06:05 PM
Guiding my way back.'s Avatar
* B A N N E D *
Default Re: (o VALTER o)
sounds like a map sensor i had mine go out when my sohc was boosted and it did the same thing
Old Nov 27, 2007 | 06:13 PM
zachvirus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o VALTER o &raquo;</TD></TR><TR><TD CLASS="quote">i thought about that, figured while i had my gas pump out, i would check for rust. advanced auto parts sells a tank for $125...</TD></TR></TABLE>
go there. that is where i got mine. its a good tank
& its overnight delivery for free.
Old Nov 27, 2007 | 06:31 PM
o VALTER o's Avatar
thats only if i find my tank has rust...the o2 sensor is what i will try to get next.
Old Nov 27, 2007 | 07:14 PM
alscrx's Avatar
My HF did the same thing and annoyed the **** out of me, I swapped the distibutor and it ran fine. It was the crank angle sensor in the dizzy
Old Nov 27, 2007 | 10:32 PM
SupraRXZ's Avatar
thanks guys ill try the dizzy, it came off a old SI that hasnt ran in a couple of years
Old Nov 28, 2007 | 12:00 AM
o VALTER o's Avatar
let me know how it turns out
Old Nov 28, 2007 | 06:06 PM
zachvirus's Avatar
that could be your problem there. try an HF dizzy
not sure the SI one would adapt properly.
used dizzy =
cant trust parts like that, rather have a new one with a Lifetime warranty
Old Nov 28, 2007 | 09:09 PM
SupraRXZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zachvirus &raquo;</TD></TR><TR><TD CLASS="quote">that could be your problem there. try an HF dizzy
used dizzy =
cant trust parts like that, rather have a new one with a Lifetime warranty</TD></TR></TABLE>
hey it was free lol
Old Nov 29, 2007 | 05:32 AM
spastik's Avatar
i just had this problem and it was my igniter.. you might check that out
Old Dec 1, 2007 | 10:51 AM
SupraRXZ's Avatar
dizzy fixed the problem
I switched out the dizzy with my old one
but i just replaced the coil on my old one so it would run again
and no more problems at all
Thanks!
Si Arn
Aug 14, 2008 11:53 AM
Rikaro
10
Jun 25, 2008 01:08 PM
DJNauTicz
20
Aug 10, 2007 10:43 PM
noob with an RS
Mar 16, 2007 01:30 PM
mi2lo4u
Nov 12, 2002 06:05 AM
