Fuel pump turns on, but not all the time???? HELP!!!!
Old Nov 26, 2007 | 05:33 PM
rdeezy78's Avatar
Default Fuel pump turns on, but not all the time???? HELP!!!!
Here's what I got. I have a 96 civic with a built motor, tuned ecu from past setup. So it's not tuned yet. Can't get the car to start the days of my tuning appt,s. Really sucks. Anyway, I have a pretty good wire tuck. My engine bay fuse box is also tucked. Now when the car was all together it started up with no problem. I get the car home and the pump doesn't want to turn on. My mechanic thinks it's the turbo timer, so I unhooked that, and the thing is, the pump will come on sometimes after I leave the key on for like a whole minute or two. But not everytime. It's really frustrating. Any help will be greatly appreciated, and yes, I already searched. Nothing related to my problem.
Old Nov 26, 2007 | 09:23 PM
quik1's Avatar
Default Re: Fuel pump turns on, but not all the time???? HELP!!!! (rdeezy78)
Sounds like a main relay problem to me. Check for power to the main relay and from the main relay to the fuel pump.
Old Nov 26, 2007 | 10:12 PM
civicstar's Avatar
Default Re: Fuel pump turns on, but not all the time???? HELP!!!! (quik1)
i agree, main relay may be going out or grounds
Old Nov 27, 2007 | 10:03 AM
rdeezy78's Avatar
thanks guys, I'll check that out.
Old Nov 27, 2007 | 02:03 PM
Relic1's Avatar
main relay or cap went bad in the ECU. both are common problems.
both are easy to fix if you can solder.
rdeezy78
Nov 28, 2007 11:18 AM
Lsweez
Jun 28, 2007 10:08 PM
ALL MOTOR DA
35
Aug 18, 2006 09:44 PM
stuckinhell
Mar 16, 2006 09:51 PM
bogus_ek
Jun 4, 2004 10:18 AM
