fuel pump or main relay???? help?
my girlfriend's car has been acting up. sometimes when it's really hot out, it won't start up. immediately i assumed it was the main relay, because it only happened when it was hot out. yesterday it finally acted up while i was in the car. sure enough we parked it, and a couple of minutes later the car wouldn't start up. so i opened the doors up to cool off the inside of the car. then i turned the key to on to listen for the fuel pump, and no pump. a couple of minutes later i did the same thing and this time there was a fuel pump. car started but died immediately, and then i turned the key to on again, and no pump. i waited again until i could hear the fuel pump, car started, i revved it to keep it going. this morning, nice and cool out, i started the car up 4 or 5 times, and each time w/ no probs. so what's the problem with the car, fuel pump, or main relay???? help me out?
Re: fuel pump or main relay???? help? (bogus_ek)
that would sum up the main relay problems really well.
take it apart and reflow the solder joints, the problem should go away.
Global Moderator
Re: fuel pump or main relay???? help? (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">that would sum up the main relay problems really well.
take it apart and reflow the solder joints, the problem should go away.</TD></TR></TABLE>
I do think this is a main relay problem.
And here are links on HOW to fix it:
http://www.markl.f9.co.uk/howt...y.htm
http://autorepair.about.com/cs...1.htm
If you need any other help or info PM me and i will gladly help you.
goodluck bro
goodluck bro
GPC91
13
10-15-2012 03:55 PM
