Fuel pump doesn't turn on everytime??? HELP!!!!
Old Nov 26, 2007 | 05:34 PM
rdeezy78's Avatar
Default Fuel pump doesn't turn on everytime??? HELP!!!!
Here's what I got. I have a 96 civic with a built motor, tuned ecu from past setup. So it's not tuned yet. Can't get the car to start the days of my tuning appt,s. Really sucks. Anyway, I have a pretty good wire tuck. My engine bay fuse box is also tucked. Now when the car was all together it started up with no problem. I get the car home and the pump doesn't want to turn on. My mechanic thinks it's the turbo timer, so I unhooked that, and the thing is, the pump will come on sometimes after I leave the key on for like a whole minute or two. But not everytime. It's really frustrating. Any help will be greatly appreciated, and yes, I already searched. Nothing related to my problem.
Old Nov 26, 2007 | 05:41 PM
beepy's Avatar
Default Re: Fuel pump doesn't turn on everytime??? HELP!!!! (rdeezy78)
Sounds like a bad fuel pump relay.
Old Nov 26, 2007 | 05:42 PM
rdeezy78's Avatar
Default Re: Fuel pump doesn't turn on everytime??? HELP!!!! (beepy)
Do you know what color wire that is, so I can check it?
Old Nov 26, 2007 | 05:58 PM
coneheadsracing's Avatar
Main relay, search, there's also how to's in most manuals on them. Have you gone over all your grounds in the engine bay, since you just wire tucked it?
Old Nov 27, 2007 | 10:04 AM
rdeezy78's Avatar
Default Re: Fuel pump doesn't turn on everytime??? HELP!!!! (coneheadsracing)
I'm going to check that out. Thanks
Old Nov 27, 2007 | 12:53 PM
JDMs1eeper's Avatar
Get mad, kick the dash. Normally helps me out.
JK. sounds like a relay. Go to the junk yard and pick one up for super cheap, grap a few spares just in case.
Old Nov 27, 2007 | 03:19 PM
rdeezy78's Avatar
Default Re: Fuel pump doesn't turn on everytime??? HELP!!!! (JDMs1eeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMs1eeper &raquo;</TD></TR><TR><TD CLASS="quote">Get mad, kick the dash. Normally helps me out.
JK. sounds like a relay. Go to the junk yard and pick one up for super cheap, grap a few spares just in case. </TD></TR></TABLE>
lol. sounds like a plan
Old Nov 27, 2007 | 03:53 PM
wade's Avatar
Does your car have an AEM EMS?
Old Nov 27, 2007 | 03:56 PM
JaredKaragen's Avatar
under the dash on the drivers side, near the hood latch area. find the relay, unplug it, unbolt the 10mm bolt holding it in place, use a screwdriver or your fingers to pop the cover off, and check out the board and find the bad solder, fix it, then drive away.
Old Nov 27, 2007 | 04:19 PM
93turbo16's Avatar
Also could be the caps in the ecu.
Old Nov 27, 2007 | 05:34 PM
rdeezy78's Avatar
Default Re: (93turbo16)
I'll check both of those. Thanks alot guys. You know how frustrating it is to get your car finished and still can't drive. It blows.
Old Nov 28, 2007 | 11:18 AM
rdeezy78's Avatar
Default Re: Fuel pump doesn't turn on everytime??? HELP!!!! (wade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade &raquo;</TD></TR><TR><TD CLASS="quote">Does your car have an AEM EMS?</TD></TR></TABLE>
no, I'm running crome.
jesus jimenez
Dec 7, 2011 06:26 AM
TurboKneeGrow
May 9, 2008 01:17 PM
rdeezy78
Nov 27, 2007 02:03 PM
ALL MOTOR DA
35
Aug 18, 2006 09:44 PM
