motor cools quickly?
Old Nov 25, 2007 | 05:41 PM
B18c1vicrx's Avatar
Default motor cools quickly?
my motor seems to cool down quicker then i think it should when i cut it off, and when i turn the heat on the temp gauge drops from right around 210 degrees to 190ish... i was just wondering if this was normal, if its not what does that mean? thanks.
Old Nov 25, 2007 | 07:22 PM
~sp33~'s Avatar
EFB055
I think its only a problem if it starts to overheat, but i have no idea what an actualy operating temperature should be. How are you getting an accurate temperature?
Old Nov 25, 2007 | 07:24 PM
Tippyman's Avatar
Default Re: motor cools quickly? (B18c1vicrx)
when you say it cools to quick, you mean when you turn the car off it cools really fast, and next time you start the car it's cool?
Old Nov 25, 2007 | 08:07 PM
hondacivic90zc's Avatar
Default Re: motor cools quickly? (Tippyman)
yeah i think that is what he is trying to say.....my '90 hatch does the same thing but i dont worry about it much.
Old Nov 25, 2007 | 08:09 PM
ludesrv's Avatar
I think he means that his engine will be warm, then he will accelerate or use the fan and it cools down?
If so, that's a thermostat.
Old Nov 25, 2007 | 09:17 PM
B18c1vicrx's Avatar
well im getting the accurate reading because i have a water temp gauge since the gauge on the tachometer is broken, but it loses heat quickly when the car is turned off and turned on a short while later...just like tippyman was asking
Old Nov 25, 2007 | 09:28 PM
hatcht9x's Avatar
Default Re: (B18c1vicrx)
I have the same problem with my heater.. I turn it on and the temp guage plumits! i would try to replace your thermostat like "ludesrv" said above.. im replacing mine this week..
Old Nov 26, 2007 | 08:46 AM
B18c1vicrx's Avatar
well if that works let me know, but in the mean time, any more suggestions?...and can't this warp my block with it quickly cooling too quick?
Old Nov 26, 2007 | 09:19 AM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18c1vicrx &raquo;</TD></TR><TR><TD CLASS="quote">well if that works let me know, but in the mean time, any more suggestions?...and can't this warp my block with it quickly cooling too quick?</TD></TR></TABLE>
Virginia eh? Well up here in Canada, sometimes the weather can be as cold as -40C, that's eh...well like really freaking cold in fahrenheit.
Our engines go from running temp to freezing cold in a matter of minutes. We don't have problem. Your fine.
Old Nov 26, 2007 | 09:23 AM
B18c1vicrx's Avatar
i use to be in the canada scene, and if it can drop that low and be fine then i guess my problem is solved
Old Nov 26, 2007 | 07:11 PM
Harlowe's Avatar
Function>Fashion
I live a couple miles from Glen Allen.
..but yea If you're too worried about it, check the thermostat.
Old Nov 26, 2007 | 07:27 PM
B18c1vicrx's Avatar
how does one check the thermostat
agb22
17
Mar 7, 2017 07:11 AM
TshingY
Jan 25, 2010 12:59 PM
floatfisher
Nov 19, 2007 09:46 AM
in10ceCiviC
Jul 19, 2007 12:10 AM
