oil return line off turbo?
Old Nov 25, 2007 | 08:07 AM
T9U4ReBgO's Avatar
Default oil return line off turbo?
ok got another question does the oil return line off the turbo have to be a straight shot or can it have a slight curve in it???? and the curve has to go up a slight bit?/
Old Nov 25, 2007 | 08:09 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: oil return line off turbo? (T9U4ReBgO)
as long as it travels continually downward, a curve is ok. just do your best to be as short as possible.
Old Nov 25, 2007 | 08:11 AM
T9U4ReBgO's Avatar
Default Re: oil return line off turbo? (boostedcivicsir)
what would happen if oil got backed up in the oil return line?
Old Nov 25, 2007 | 08:14 AM
Mr. Badwrench
will push past your seals and make lotsa smoke, and fill up your intercooler with oil.
Old Nov 25, 2007 | 08:18 AM
turbodano's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T9U4ReBgO &raquo;</TD></TR><TR><TD CLASS="quote">what would happen if oil got backed up in the oil return line?</TD></TR></TABLE>
The turbo would smoke like a freight train and would end up going out.
There should be no 90 degree turns in the drain a 45 is ok and the inside of the return line should be no smaller then 13mm or 1/2 inch.
Old Nov 25, 2007 | 11:56 AM
fireman mike2288's Avatar
no oil means NEW turbo lol
Old Nov 25, 2007 | 12:09 PM
Schister66's Avatar
Man U FTW
Default Re: (fireman mike2288)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireman mike2288 &raquo;</TD></TR><TR><TD CLASS="quote">no oil means NEW turbo lol </TD></TR></TABLE>
Good thing that's what they were talking about
As long as the oil line is going downward, you should be ok. Try to avoid flat spots and curving back upward because oil will pool in those areas.
Old Nov 25, 2007 | 12:25 PM
blackeg's Avatar
Default Re: (Schister66)
yeah it can curve, mine does. just as people say make sure its always going down and doesnt have any flat spots or dips in it because its all gravity fed
Old Nov 25, 2007 | 02:44 PM
T9U4ReBgO's Avatar
Default Re: (blackeg)
blackeg do u have a pic of urs or does anybody have a picture I could go by?
"00"R
Jun 21, 2007 10:48 AM
bboyfreeze
Apr 2, 2007 08:38 PM
civictypenos
Jul 18, 2005 01:54 PM
TA Performance
Feb 6, 2005 12:27 PM
slo_crx
Oct 6, 2004 08:30 AM
