valves ticking
Old Nov 24, 2007 | 02:23 PM
97BB6Type-SH's Avatar
Default valves ticking
my 97 type-sh just went over 150,000 miles and now my valves are ticking. ive owned it for the past year and a half, since it had 135,000 and have always changed the oil every 3,000 miles using mobil 1 10w-40 synthetic. normally i hear the valves tick when im low on oil so when i heard it i decided to do an oil change and normally the noise always goes away when i change it, but this time the noise persist after i changed the oil. do u guys think if i adjust my valves the noise will go away? because i searched and read that alot of people adjust them and the noise doesnt go away. or should my oil be thicker? what do you guys recommend? the noise is not loud it just bothers me knowing something isnt right. thanks
Old Nov 24, 2007 | 02:32 PM
mattsnooz's Avatar
Default Re: valves ticking (97BB6Type-SH)
What, you havn't done a valve lash adjustment? Its part of routine maintenance to have your valve lash inspected and adjusted.
Old Nov 24, 2007 | 03:04 PM
prelude1897's Avatar
Default Re: valves ticking (mattsnooz)
probably time to do a valve adjustment. That'll lower the noise and save gas. There are a lot of people in FL who work on Prelude who can probably help you out. Just check out http://www.sfpoa.net
Old Nov 24, 2007 | 03:20 PM
InvaderTrax's Avatar
Valve adjustment or just Honda Tick
Old Nov 24, 2007 | 04:27 PM
Default Re: (InvaderTrax)
thanks all of you for the help. especially the florida site that i didnt know about. also, after the valve adjustment should i keep on with the Mobil 1 high mileage 10w-40 synthetic? or something thinner or thicker? thanks
Old Nov 24, 2007 | 05:12 PM
gogunkergorilla's Avatar
Default Re: (97BB6Type-SH)
Try checking your valve lash and switching to 10w-30. It just could be that your letting it run low depending on how low.
Jhicks
Feb 3, 2012 05:58 AM
jaredvabeach
Apr 27, 2008 04:30 PM
For_Sale
Jul 12, 2006 10:50 AM
ITR-00-1457
Mar 29, 2006 09:38 AM
do what
11
Oct 25, 2005 12:34 PM
