evo 3 16g 300 WHP?
Old Nov 22, 2007 | 09:07 PM
umair's Avatar
Default evo 3 16g 300 WHP?
i might turbo my stock b16 this winter(motor has 4000 miles on it) and i want to use an evo 3 16g. i want to make 300-310 whp on race gas(everyone keeps telling me that i cant but i know i can) and 250-260 whp on pump gas. i just wanted to know if i can make that kind of power on the turbo i want to use and when do you guys think i will hit full boost(i am going to guess 3500-400 rpms). what do i have to change in order to make that turbo fit on a b16? i tried to do some searching but i didn't come up with much info because not many people use these turbos on hondas.
are the ebay evo 3 16gs any good?
this is a list of everything i am going to get for my turbo kit.
-Turbo(evo 3 16g)
-injectors (550 cc)
-intercooler
-Oil line kit
-Engine management(hondata s200 or s300)
-boost gauge
-boost controller
- O2 bungs for the downpipe
-custom downpipe
-custom intercooler pipes
-Blow Off Valve
-turbo manifold
i know this is not the right place to ask this question but does anyone know of any good tune shops near chicago?
thanks
Old Nov 22, 2007 | 09:20 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: evo 3 16g 300 WHP? (umair)
edited your thread title for you, and there is a sticky at the top with a list of tuners.
listed under IL
Suprdave of The Whip Factory
-630-922-3327
-http://dave@whipfactory.com
-Specialize in Hondata, Neptune, K-Pro, can do other systems...
Old Nov 22, 2007 | 09:34 PM
melovesboost's Avatar
Dont forget that the EVO 16g is a twin scroll turbo so you gotta find a flange for that or an adapter of some sort
Old Nov 22, 2007 | 09:39 PM
JDMeg95's Avatar
Default Re: (melovesboost)
lots of people use mitsu turbos on hondas.....and yes you can deffinatley hit 300whp with an evo 3
Old Nov 22, 2007 | 10:13 PM
Vince64's Avatar
Default Re: (JDMeg95)
i thought the evo 3 16gs were open?
The evo 8 16g is the best, cheapest, dual internally gated, divided turbo on the market for round 300 whp.
My brother has a Evo 8 big 16g on his gsr integra and it rips. If i remember right he made 270 whp with bone stock gsr, FULL 2.5 inch exhuast (and i mean resonator and a real muffler, 2.5 inch cat) on 11 lbs. Its super quiet and can pass emissions.
I myself am planning on putting a evo 8 16g on my b16. 300 whp on pump should be no problem on a bone stock engine.
Old Nov 23, 2007 | 07:13 AM
TiAL's Avatar
Default Re: (Vince64)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vince64 &raquo;</TD></TR><TR><TD CLASS="quote">i thought the evo 3 16gs were open?
you are correct
and do not but the eBay Evo III 16g 'GT' turbo, it's china junk
Old Nov 23, 2007 | 08:01 AM
SOHC_MShue's Avatar
this turbo performed great on my buddy's non vtec sohc f22. 270whp on 9psi.
Old Nov 23, 2007 | 08:33 AM
umair's Avatar
i heard that these turbos have boost creep problems. is their any way that problem can be fixed? i also wanted to know will this turbo stop making power at high rpms.
Old Nov 23, 2007 | 10:35 AM
turbodano's Avatar
Default Re: (umair)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by umair &raquo;</TD></TR><TR><TD CLASS="quote">i heard that these turbos have boost creep problems. is their any way that problem can be fixed? i also wanted to know will this turbo stop making power at high rpms. </TD></TR></TABLE>
It is an easy fix the wastegate flapper and wastegate hole need to be enlarged. We have the upgraded pucks and any machine shop can make the hole larger. We use a 1.200 drill.
Old Nov 23, 2007 | 01:00 PM
bch5428's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by melovesboost &raquo;</TD></TR><TR><TD CLASS="quote">Dont forget that the EVO 16g is a twin scroll turbo so you gotta find a flange for that or an adapter of some sort</TD></TR></TABLE>
only the new evos are twin scroll.
i used an ebay evo 3 big 16g and it lasted 28 miles
bought a real one and its been working fine for almost 2 years.
the only complaint i have with this turbo is the hot side charge pipe set up. it requires more fabrications than typical set ups IMO, not a big deal but requires some creativity.
i plan on maxing this turbo out next spring on my d series, i bet it would be a blast on a stock bottom end b series.
Modified by bch5428 at 2:17 PM 11/23/2007
Old Nov 23, 2007 | 03:51 PM
umair's Avatar
thanks for all the replies. how long will my motor last if i have 250-260 WHP on pump gas and 300+ on race gas?
Old Nov 23, 2007 | 04:17 PM
Mr. Badwrench
Default Re: (umair)
tough to say. if the engine is sound, the tune good, should " should " being the opperative word, last a good while.
JDMeg95's Avatar
Default Re: (umair)
that all depends on the tune
Old Nov 23, 2007 | 04:32 PM
Sr420Det's Avatar
It shouldnt be hard at all to achieve your goals on a b16. I think you should be able to reach 280-300 hp on pump gas and what you plan on running. You might need a few unmentioned goodies, like a clutch and a fuel pump. I dont know much about the turbo but im pretty sure its good for 300 hp. Good luck with the build.
Old Nov 23, 2007 | 04:45 PM
RCautoworks's Avatar
We can build you a downpipe, and if you use the 16g flanges turbo ( not the twin scroll ) we can build you a ram for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by umair &raquo;</TD></TR><TR><TD CLASS="quote">thanks for all the replies. how long will my motor last if i have 250-260 WHP on pump gas and 300+ on race gas? </TD></TR></TABLE>
We got a gsr pushing 300hp out there, has been running fine for years now, tuned by factory five motorsports. Its a daily driven car, rain, snow, sleet, hail, engine is still running strong.
Old Nov 23, 2007 | 07:14 PM
umair's Avatar
i will be giving you guys a call when i get my turbo. can you pm me and tell me how much it will be?
i just hope my b16 runs for years.
Old Nov 23, 2007 | 07:23 PM
Schister66's Avatar
Man U FTW
I've been at 315whp for a while on my bone stock GSR and it seems to be working just fine....you should be safe at 300whp
civichatch2307
Aug 6, 2007 05:53 PM
big-cat
14
May 13, 2006 04:17 PM
boosted89si
Aug 28, 2004 04:18 PM
OEMJDM
Jan 21, 2003 03:37 PM
GSteg
Dec 28, 2001 12:30 PM
