Peeling off stickers...
What is your method? I hear some use a blow dryer to heat up the glue under the sticker. I was just going to peel it off and use goo gone or something similar. I don't have a blow dryer and am not going to buy one just to peel off stickers. Thanks for any advice.
i use a heat gun on low setting and peel from acorner. use the heat gun to keep the rest of the sticker warm and peel it off little by little.
i use WD40 to get rid of the adhesive because i noticed goo gone leaves swirls on your plastics.
i've destickered all of my bikes.
go for like an hour ride to heat the entire bike up, then peel the corner of the sticker and squirt wd40 onto it, and it will break the sticker glue down
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J K R »</TD></TR><TR><TD CLASS="quote">oh Thanks man....do you think i could just try to peel it off without a heat gun and use wd40?</TD></TR></TABLE>
you could try it, but you'd more then likely be there for hours. just do what immortal said, grab a heat gun, or blow dryer.
oops sorry brain fart.... heres the link...www.tapeworks.com
Hair dryer or a heat gun is best.
Although I once removed all the decals from a set of f4i fairings with a Bic lighter.... I wouldn;t recommend that method though
integrator43
Honda Motorcycles
17
Mar 10, 2005 01:03 AM
