stick with d16y7 or swap ?!
Old Nov 22, 2007 | 08:58 AM
Ek9_Chri$'s Avatar
Default stick with d16y7 or swap ?!
yea i have a d16y7 all stock.. its been giving me some problems but motor is still strong. my friends tell me that i could make a d16y7 pretty quick but its just going to take a lot of work. i dont know what to do but i swap sounds much easier but i want respect. it would help for more peoples opinions. thanks i appreciate it
Old Nov 22, 2007 | 09:02 AM
platinumx6's Avatar
Default Re: stick with d16y7 or swap ?! (Ek9_Chri$)
whats your budget.
Old Nov 22, 2007 | 09:08 AM
bcod151's Avatar
Default Re: stick with d16y7 or swap ?! (platinumx6)
In my opinion I would go with a swap ( B Series) then go from there!
Old Nov 22, 2007 | 09:11 AM
forcefedferio's Avatar
What it really comes down to is what you want to do with the car. If you just want a quick car, i would swap in a d16y8 and turbo it. You can turbo your y7, but that won't solve your problems you are having with it. Plus, with how straightforward swapping a y8 would be compared to the amount of power you would see between the two, it wouldn't be worth it not to swap.
Example: Two of my friends cars.
96 Civic coupe d16y7, SSAC t25 turbo kit on 10psi-175 whp
94 Civic coupe d16z6 (same as y8 for argument's sake) SSAC t25 turbo kit on 10 psi- 207 whp.
same exact turbo kits, same exact boost the z6 made 30 more wheel horsepower. The Z6 turbo actually made 187 ft. lbs. of torque as well, which is more whp than the y7 made, that should tell you something right there. haha
Old Nov 22, 2007 | 10:05 AM
ej6onlsd's Avatar
If you're on a budget, boost a z6. You can build it up piece at a time and do it right. If you aren't on a budget, H2B that piece.
Tagman87
18
Jun 12, 2012 07:44 AM
gizzm619
May 13, 2009 10:51 PM
hondacharged
15
Nov 11, 2008 10:22 PM
99sibluehatchwitb16
19
Jan 19, 2006 08:29 PM
sporty240
Apr 27, 2004 11:47 AM
