need help//bad
Old Nov 22, 2007 | 08:03 AM
jonny_sin's Avatar
Default need help//bad
ok so 2 weeks ago my greddy cam gear shattered while i was driving back home.of course i bent valves, 8 to be exact. so i tore the head apart and replaced all the valves and set everything back.
m problem is that now i have a rowdy misfire.the car will stay on,but with lil to no power.has a bad hesitation problem.timing is correct.can someone help me if this has happened to you guys.
ohh i forgot to mention it's a d16z6 motor
Old Nov 22, 2007 | 08:11 AM
Luserkid's Avatar
Default Re: need help//bad (jonny_sin)
Did you do your valve adjustment?
Old Nov 22, 2007 | 08:26 AM
jonny_sin's Avatar
Default Re: need help//bad (Luserkid)
yeah man i did
i can't figure it out.
Old Nov 22, 2007 | 04:05 PM
jonny_sin's Avatar
damn no one. or is everyone just acting the fool right now
Old Nov 22, 2007 | 04:55 PM
ejoner's Avatar
Default Re: (jonny_sin)
Did you put in new plugs? Try pulling a plug wire at a time to see if its an actual miss fire. Are you throwing any codes?
Old Nov 23, 2007 | 08:49 AM
jonny_sin's Avatar
ok i got the car to runwith out misfire..now i have another problem.
the car doesn't want to stay at idle.lmao
man this car is beating me..
i can keep it at idle with my foot on the accelerator but once i take my foot off the car dies completly like if i shut it down..hmmmm
any help can be apreciated...i need to have the car to stay running so i can check for codes.
Old Nov 23, 2007 | 09:13 AM
jonny_sin's Avatar
damn no one has an answer
Old Nov 23, 2007 | 09:23 AM
Big M Built's Avatar
if you bent the valves most likley you dented your valve seats causing incorrect seating/compression leak.....everyone i know that has bent a valve has either bought a new head or if the damage wasnt severe, a machine shop re-shaped/cut the seats......even if it didnt look like they were dented, they most likley were enough for new valves not to seat correctly
Old Nov 23, 2007 | 09:28 AM
jonny_sin's Avatar
no i replaced the valves and also did a leak test. the alves set right and there was no major damage on the head besides the valves. the compression on it is good .
it is something else
Old Nov 23, 2007 | 10:01 AM
not for nothin but, check your rotor on the dizzy....sometimes the screw will fall out and it'll be off timing.....if thats not it, try your belt timing one more time....make sure that the crank pulley (single mark)is lined up with the mark on the timing cover and make sure the cam gear isnt 180 off....i seen that happen ALOT.....not saying i dont think you dont know what your doing but sometimes even a good mechanic will overlook the smallest thing....you can be one tooth off....or 180.....look carefully
Old Nov 23, 2007 | 10:18 AM
jonny_sin's Avatar
lol..funny you say that, but i doubted myself when i did the timing and thought it might be that. but no thank god.lol
Old Nov 23, 2007 | 10:33 AM
lol yeh idk mann....if i lived near you we'd figure it out cuz i cant figure it out instantly through the internet.....but try finding someone local to take a look at it...im sure its probably nothin too big....its only a honda!!! but good luck
Old Nov 23, 2007 | 11:34 AM
jonny_sin's Avatar
hahaha thanks man..but yeah i got a couple of friends swinging by.but since it is the holidays so it's kind of hard...
well im a try something .wich i have been overlooking.but it's my final shot..
i'll let you guys know if it works
Old Nov 23, 2007 | 01:30 PM
jonny_sin's Avatar
ok i got it to the last thing it might be.
well after holding my foot on the gas pedal for 5 minutes i let goand it stayed idling low at 500 rpm then it jumped up to normal levels..so i checked the motor and noticed the water temp sensor had a clipped wire..and now it stays as long as it doesn't cool down..hmm well im a switch it out and then see what happens
chickenhawk44
Aug 14, 2012 08:42 PM
joseek
Feb 24, 2011 10:16 AM
0h0hdc2
Aug 20, 2006 07:02 PM
1.7na
May 31, 2004 07:12 PM
VtecNit01
Oct 11, 2001 07:22 AM
