Trans Problem...
Old Nov 21, 2007 | 12:25 PM
jmeyoung120's Avatar
TRIAL USER
Default Trans Problem...
Its a 98 ex and I have to pretty much release the clutch pedal all the way just to get the car moving. Also when I am decelerating I can hear a kind of whining/shuffling noise from the trans.
I was driving it today and when I would be shifting from first to second it seemed like it was in gear but when I released the clutch it would just rev until I jammed it into second, then seemed to work ok after. Happened a couple of times today.
In addition the car is idling pretty low. At start up its normal and when it gets warm it seems to ok but after ive been driving a little it idles around 400-500rpm. Im not sure if that has anything to do with the trans or not.
Any ideas? Is it just the clutch?
Thanks in advance if you can help out!
sucks cause I just bought the car.
Modified by jmeyoung120 at 1:38 PM 11/21/2007
Modified by jmeyoung120 at 1:41 PM 11/21/2007
Stock03Accord
Jul 5, 2018 05:24 AM
Cuda
Dec 31, 2007 07:05 PM
jmeyoung120
Nov 26, 2007 12:08 PM
InteGSR01
Honda S2000
Oct 10, 2007 11:20 PM
86si
Feb 3, 2006 12:04 PM
