how to identify turbonetics turbo with no compressor housing.
Old Nov 20, 2007 | 06:45 PM
Beau Gotti's Avatar
Default how to identify turbonetics turbo with no compressor housing.
I picked up a turbonetics T3 turbo today for my SOHC set up, but there are no serial numbers on the turbo. How can I identify the turbo? What i do know is that it is a T3 not a T3/T4. It has a 5 bolt downpipe flange, and is external wastegate. It's in pretty good shape just needs that compressor housing.
Thankz!
Old Nov 21, 2007 | 12:08 AM
Schister66's Avatar
Man U FTW
Look for any markings on the turbo and google it...also different companies use different compressor housing backing plates. What color/design is it?? If you could post pictures, that would be the easiest way of determining what you have...
Old Nov 21, 2007 | 05:22 AM
Beau Gotti's Avatar
Old Nov 21, 2007 | 05:25 AM
Schister66's Avatar
Man U FTW
Next time you take close-up pictures, push the little flower button on your camera. You'll actually be able to see what you photograph
Anyway, that looks like the casting mark "T" that Turbonetcis uses to mark their stuff....as for specs and trim, you'd have to measure the inducer/exducer of both wheels and give us measurements...Do you have a micrometer?
Old Nov 21, 2007 | 05:36 AM
turbodano's Avatar
Default Re: (Schister66)
It looks like a 50 trim with a jd 350 turbine wheel. That turbo combo is a good 400 whp combo. The bad thing is the parts look very bad and things are missing like the compressor nut. I would take it to a turbo shop and see what they have to say about it. Also if it is a ball bearing unit it will more than likely need to go back to Turbonetics for repair which is going to cost as much as a new one.
Long story short it don't look like you have much to work with.
Sorry dude.
Old Nov 21, 2007 | 08:47 AM
Finland's Avatar
there should be a 5 digit number cast into the side of the turbine inlet flange, that number will tell you what housing it is.
Old Nov 21, 2007 | 12:58 PM
Beau Gotti's Avatar
well it came off of a turbonetics kit, the car caught of fire and burnt off the compressor housing lol, i got it for free, im gonna look into cheapturbo.com.
Old Nov 23, 2007 | 02:06 PM
Beau Gotti's Avatar
ive taken the turbo as far as part as i can, and there are NO numbers? does the wheel need to be measured with a mivrometer or can it be with a tape measure?
ay_billy
Aug 18, 2012 03:57 AM
PeakBoost
Nov 17, 2005 07:27 AM
zeroz
Aug 30, 2005 10:22 PM
carsaregood
Jan 8, 2004 04:40 PM
95 LS
Apr 16, 2002 05:18 AM
