quick rod bearing ?
Old Nov 20, 2007 | 05:11 PM
LS AzZkIkr's Avatar
Default quick rod bearing ?
I was just wondering if there was a difference in acl bearings and acl RACE bearings? This is the deciding factor in a gasket/rebuild kit off of ebay. thanks for any help!
Old Nov 20, 2007 | 05:50 PM
night's Avatar
Default Re: quick rod bearing ? (LS AzZkIkr)
http://www.aclperformance.com....s.htm
http://www.acl.com.au/
from what i can gather both race and duraglide are the trimetal, while the Aluglide is not.
but just go with the race..
i've never used acl's yet.
Old Nov 20, 2007 | 05:55 PM
ToeJam's Avatar
Default Re: quick rod bearing ? (night)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by night &raquo;</TD></TR><TR><TD CLASS="quote">http://www.aclperformance.com....s.htm
i've never used acl's yet.</TD></TR></TABLE>
i believe race gives more clearance. go with the std for DD.
Old Nov 20, 2007 | 06:13 PM
LS AzZkIkr's Avatar
Default Re: quick rod bearing ? (ToeJam)
Thanks alot!!!! I have used the standard duraglide bearings on 4 motors i have rebuilt and never had any problems. This LS/Vtec build i am doing is just to finally have a fresh pretty much stock engine while i save up for a sleeved block and better internals. I appreciate the input!
Old Nov 20, 2007 | 10:53 PM
Combustion Contraption's Avatar
The 'race' series has an extra .001" of clearance.
Old Nov 21, 2007 | 08:17 AM
DonF's Avatar
Default Re: (Combustion Contraption)
The Race bearing with a HX part number (the X) means extra clearance, the Race bearing with a H part number (no X) are standard size. The Race main bearings also help with better crank oiling to the rods.
Old Nov 21, 2007 | 05:07 PM
LS AzZkIkr's Avatar
Default Re: (DonF)
so is it worth the money to get these bearings for basically factory build/rebuild? this motor is just to get me a fresh, reliable, factory motor. yeah i most likely will go to the track a few times and beat on it a bit.
crashsvg
Jan 9, 2014 05:30 AM
Dublocivic
Jan 16, 2006 06:23 PM
RACEPAK
24
Nov 9, 2005 11:08 AM
VWkila
May 7, 2005 12:20 PM
IntegraB18
Feb 6, 2005 04:16 PM
