Bearings?
Old Feb 4, 2005 | 05:06 PM
IntegraB18's Avatar
Default Bearings?
what kinda rod and main bearings are u guys runnin on ur race motors?..oem or acl or other?
thanks
Old Feb 4, 2005 | 05:32 PM
buck02's Avatar
Default Re: Bearings? (IntegraB18)
clevite 777
Old Feb 4, 2005 | 06:43 PM
SpeedDreamz.com's Avatar
Default Re: Bearings? (buck02)
oe
Old Feb 4, 2005 | 06:47 PM
ninesecrx's Avatar
Default Re: Bearings? (30psiCiv)
ACL
Old Feb 4, 2005 | 07:08 PM
N2O's Avatar
N2O
Default Re: Bearings? (ninesecrx)
OE Rod and ACL main. Never changed the mains all season and the looked great after 70 plus hard passes.
Old Feb 4, 2005 | 11:13 PM
Quik Chris's Avatar
Default Re: Bearings? (N2O)
ACL in everything. Never had it plastigauge wrong.
Old Feb 4, 2005 | 11:34 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Bearings? (Quik Chris)
ONLY OEM.
Old Feb 5, 2005 | 05:45 AM
tony1's Avatar
Default Re: Bearings? (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">ONLY OEM.</TD></TR></TABLE>
Old Feb 5, 2005 | 05:57 AM
SSC1's Avatar
Default Re: Bearings? (tony1)
We run ACL's new "H" series race bearings coated by calico. Holding up perfectly!!
Old Feb 5, 2005 | 05:59 AM
tony1's Avatar
Default Re: Bearings? (SSC1)
Someone posted this a long time ago, I though it was interesting reading...
http://www.g-speed.com/pbh/ae-...aring
Old Feb 5, 2005 | 07:29 AM
earl's Avatar
Interesting reading as to what Honda was trying to accomplish 10-15 years ago. Makes you realize how old some of our "current" technology is
Old Feb 5, 2005 | 07:58 AM
Suprdave's Avatar
Word...
Old Feb 5, 2005 | 08:03 AM
tony1's Avatar
Default Re: Bearings? (earl)
I've got a great book about Honda's Turbo F1 program, you'd be amazed at the technology they had in the mid to late 80's!
Old Feb 5, 2005 | 03:41 PM
Chain Driven's Avatar
ACL
Old Feb 5, 2005 | 06:30 PM
ExospeedAMcrx's Avatar
OEM only. When you do the measurements on different rods, you can never be too sure to put in the RIGHT size to get all the same clearances that you want.
You can't assume that X rods and Y rods and A Rods will all have the same exact precise machining process. Add the crank factor and then the block factor. There's just too many chances of one of those being off.
Old Feb 5, 2005 | 06:34 PM
we even use OEM GSR bearings in certain D16a6 builds.
Old Feb 5, 2005 | 09:03 PM
earl's Avatar
Default Re: (exospeedAMcrx)
Can anyone tell me what exact clearance you are looking for when building a motor with Honda colors? The Helms manual gives you such a large operating variance that any color bearing you put in there will be in the acceptable range.
In most cases, I think people just use the colors so they won't have to measure anything.
Old Feb 5, 2005 | 10:12 PM
Have you ever encountered certain rods that have uneven sizes.
Have you received cranks from customers that after being measured, you have to use colors from both ends of the spectrum.
What do you do then?
I don't think its not having to measure anything. I think its a matter of being precise.
Old Feb 6, 2005 | 05:09 AM
IntegraB18's Avatar
thanks for the input
Old Feb 6, 2005 | 09:14 AM
earl's Avatar
As to rods, I would never use a set of rods that all 4 do not match.
But my real point is that no one can say what is the exact clearance Honda says is correct.
Is it .0013", .0015", .0017" or .00XX? If you say that only a color bearing gives you proper clearance, how do you take into account that these clearances were established for 6500 rpm engines making 150 hp back in the mid 1990's?
Old Feb 6, 2005 | 09:58 AM
fknfast's Avatar
Default Re: (earl)
whats the difference between ACL and OEM?
Old Feb 6, 2005 | 10:21 AM
earl's Avatar
Default Re: (fknfast)
They are both a trimetal designed bearing unlike the standard bi-metals
Old Feb 6, 2005 | 11:36 AM
Jared's Avatar
Default Re: (earl)
so what clearances do you guys like to use on a high hp application, especially those without oil squirters?
Old Feb 6, 2005 | 02:23 PM
HR-1320's Avatar
Default Re: (Jared)
What like 1000hp .002 - .0025 . Fedrel Mogul bearings
Old Feb 6, 2005 | 04:16 PM
Johnny O A20 KIller's Avatar
These companies who you guys are talking about have listings for Honda motor or you have to mock them up.Let me know I am interrested in this knowledge.I use Honda bearings in my motor.
jordan2305
Aug 18, 2007 08:19 PM
kornerk12
Feb 13, 2007 09:02 AM
haysr
12
Jul 31, 2005 09:39 AM
turbolude831
Sep 22, 2004 10:18 PM
PM-Performance
May 28, 2003 10:02 PM
