Can I use OEM Injector Seals on RC Injectors?
Old Nov 20, 2007 | 04:17 PM
96 GSR-T's Avatar
Default Can I use OEM Injector Seals on RC Injectors?
As stated, will there be any issues, talking about the intake manifold seal
Thanks
Old Nov 20, 2007 | 04:32 PM
platinum00's Avatar
Default Re: Can I use OEM Injector Seals on RC Injectors? (96 GSR-T)
The outside diameter is the same and I believe the inside is as well. If not you should easily be able to bore the OEM seals to fit.
-platinum
B R Fittings's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">As stated, will there be any issues, talking about the intake manifold seal
Thanks</TD></TR></TABLE>
I used them on my RC 750's without a problem.
Old Nov 20, 2007 | 05:47 PM
96 GSR-T's Avatar
thanks fella's, Platinum.... how could I bore an injector seal? they are soft plastic not hard so drilling would be impossible I would think.
Old Nov 20, 2007 | 05:58 PM
JRSC01GS-R's Avatar
Default Re: (96 GSR-T)
i used my dremel with a sanding drum on it. My inside diameter needed to be enlarged to fit my rc injectors. depending on which style u have they may fit into your stock grommets just fine
Old Nov 20, 2007 | 06:59 PM
nihad's Avatar
get some from the parts store and make sure they fit they sell them cheap 4$ for 4 make sure they are
fuel type.
Old Nov 20, 2007 | 07:04 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
i also bored a pair out for some dsm 450's a while back with a dremel, just be sure not to do it too much
Old Nov 21, 2007 | 03:46 AM
platinum00's Avatar
Default Re: (tannerLSt)
You can also goto NAPA and get a injector seal kit and it comes with multiple size injector seals. Alot used to go this route when running DSM 450's
Good luck..
-platinum
Old Nov 21, 2007 | 04:49 AM
Schister66's Avatar
Man U FTW
Use a dremel and bore them out...make sure they dont leak like crazy though. I run stock O-rings with my RC550s
Old Nov 23, 2007 | 04:54 PM
boostede46's Avatar
I USED MY OEM DUE TO THE RC O'RINGS RIPPING...YOU SHOULD BE FINE
Old Nov 23, 2007 | 07:22 PM
95dc2teg's Avatar
Default Re: (boostede46)
i just used the stock ones that were on there and squeezed those ****'s in, no problems
EX-T
Aug 29, 2007 09:35 AM
maxspeedhonda
Aug 27, 2004 12:06 PM
Blackack26
Feb 20, 2004 10:59 AM
