oil pressure switch or sanwhich adapter?
Old Nov 19, 2007 | 07:46 PM
laocivic's Avatar
Default oil pressure switch or sanwhich adapter?
which is more reliable to use on a turbo setup?
im gonna be running a stock gsr with a t3/t4 57 trim a/r 63 turbo.
Old Nov 20, 2007 | 06:03 AM
sleepencivic's Avatar
Default Re: oil pressure switch or sanwhich adapter? (laocivic)
id run the T off the switch i have seen a few leaky sandwich adapters over the last few years if you do go with the sandwich get the goldeneagle and hondabond it
Old Nov 20, 2007 | 11:59 AM
blackeg's Avatar
Default Re: oil pressure switch or sanwhich adapter? (sleepencivic)
i dunno about having to hondabond. if your concerned the new o rings are 4 bucks each from golden eagle.
be carefull threading things into the pressure sensor hole on the block. 12 ftlbs i think and no more. ive broken a few in my day and my block had to be welded shut there
Old Nov 20, 2007 | 12:02 PM
laocivic's Avatar
Default Re: oil pressure switch or sanwhich adapter? (blackeg)
so as long as i get an adapter that is good ill b ok? that switch is a bitch to get out
Old Nov 20, 2007 | 12:54 PM
B20luda's Avatar
i have the GE adapter, i have 2 lines running out, 1 for additional oil to the cylinder head and the other going to the turbo, i installed all fitings with liquid thread sealant they were COMPLETLY clean and dry when installed, my **** dont leak a drop....
Vibration can also take its toll on cheap brass fitting being pressured by the oil lines etc, i wouldnt do it that way...
Old Nov 20, 2007 | 01:58 PM
vietjdmboi's Avatar
the T fitting from the sensor hole isnt the best idea. a friend of mine broke his fitting b/c of the weight and vibration hanging off the end. i would definitely go with an oil sandwich adapter.
Old Nov 20, 2007 | 06:26 PM
laocivic's Avatar
Default Re: (vietjdmboi)
ok so sandwich plate it is thanks everyone
Old Nov 21, 2007 | 05:11 AM
Default Re: (laocivic)
there are lots of cars using the T out there and no problem...from fast-turbo to steathmodperformance kits they work and last...
GoSickemRobert
Mar 29, 2011 09:47 PM
gsr96cx
Dec 23, 2010 07:09 PM
ARIZONA
Aug 31, 2004 07:30 PM
pelotudo
Aug 18, 2002 06:31 PM
