oil pressure switch or sanwhich adapter?
which is more reliable to use on a turbo setup?
im gonna be running a stock gsr with a t3/t4 57 trim a/r 63 turbo.
Re: oil pressure switch or sanwhich adapter? (laocivic)
id run the T off the switch i have seen a few leaky sandwich adapters over the last few years if you do go with the sandwich get the goldeneagle and hondabond it
Re: oil pressure switch or sanwhich adapter? (sleepencivic)
i dunno about having to hondabond. if your concerned the new o rings are 4 bucks each from golden eagle.
be carefull threading things into the pressure sensor hole on the block. 12 ftlbs i think and no more. ive broken a few in my day and my block had to be welded shut there
i have the GE adapter, i have 2 lines running out, 1 for additional oil to the cylinder head and the other going to the turbo, i installed all fitings with liquid thread sealant they were COMPLETLY clean and dry when installed, my **** dont leak a drop....
Vibration can also take its toll on cheap brass fitting being pressured by the oil lines etc, i wouldnt do it that way...
the T fitting from the sensor hole isnt the best idea. a friend of mine broke his fitting b/c of the weight and vibration hanging off the end. i would definitely go with an oil sandwich adapter.
gsr96cx
12-23-2010 07:09 PM
ARIZONA
08-31-2004 07:30 PM
pelotudo
08-18-2002 06:31 PM
