building b16 while out of the car...
ok. i got my b16 second gen and its sitting in my garage right now. i got $1500 left over from when i bought it. my friend says i should use the money to build the bottom end and tranny while its out of the car. im just looking for suggestions or things i may not have thought of. i do need lsd though so im thinking about it.
thanx for any help or suggestions.
first check all the parts, get new timing belt, check the water pump/oil pumps, replace the spark plugs (if necessary), new rotor/distributor cap, check the seals all around as well...if all is good then move on to performance goods
definatly get Quaife or Kaaz = $800-1000
lightweight flywheel or ITR or lighten yours = $120-350
CTR/ITR intake cam = $250
ITR intake manifold = $250
or
header = $300-400 for DC JDM 2.5" ( test pipe or custom cat)
other choices are ecu chipping, boring out the TB
or
I have a second gen B16 sitting in my garage too.
Here is what I have/installing:
CTR cams
Skunk2 cam gears
ITR intake manifold
Portflow inner valve spring/ITR outer v.s.
Portflow Titanium retainers
DC header
Re-chipped P28
V-AFC
Exedy Clutch/clutchmaster flywheel
Port and Polish + 3 angle
Along with the aftermarket stuff I bought new from Honda:
Timing Belt
Alternator Belt
Water pump
All gaskets
Fuel Filter
Thermostat
Hope this helps you out.
[Modified by blackANESE, 7:30 PM 6/24/2002]
CTR cams
Skunk2 cam gears
ITR intake manifold
DC header
Re-chipped P28
V-AFC
Timing Belt
Alternator Belt
Water pump
All gaskets
Fuel Filter
Thermostat
wow thanx. that helps alot. i got a pr3 ecu with it. i dont know if its obd1 or 2. i was told 1. but anyways, do you think i should go for a chipped p-28?
I went with a re-chipped p28 to have a little higher redline and have optimized fuel maps. Not really necessary but I wanted it. The PR3 should work fine.
What car is it going into??
you seem to know your shiz. anyways...its going in a 96 civic hatch. obd-2 so its a problem. i know i need the conversion harness.
My suggestion:
Sell the shortblock and buy a GSR shortblock. While it`s apart swap out the pistons for R pistons. Add CTR cams, gears, etc. and tune.
The best bang for the buck is obviously going 1.8 IMO. This is still very reliable, too.
Ryan
Ryan
ohhh..ryan got jokes..i dont even know what to say to that..u always got me in IR too..****..thats what i get for being the token black guy.
but..dont ever call me jarule..i hate that guy.
anywas if u r a baller like ryan source a 1.8 vtec bottom. or just build what u have with all the R goodies!
[Modified by JaeOne3345, 5:35 AM 6/25/2002]
TypeRbuild718
May 7, 2007 03:17 AM
