overheating question??
Old Nov 19, 2007 | 11:01 AM
KeEpxiTxLiTt's Avatar
Default overheating question??
wuts da worst thing that kuld happen if ur car overheats hella bad??
Old Nov 19, 2007 | 11:20 AM
95ProjectEJ1's Avatar
Default Re: overheating question??
You could warp the head... that is always fun.
What is the problem? Fan not activating? Blowing white smoke? Coolant in your oil?
Old Nov 19, 2007 | 11:56 AM
Default Re: overheating question?? (95ProjectEJ1)
iono y it always overheats .. my car laggs wen its overheating but wen da car is cold it drives normal.. any tips??
Old Nov 19, 2007 | 12:02 PM
Check for leaks
Burp the system to realease any air bubbles. To do this remove the radiator cap when the car is cold and start it up in your driveway. Let it reach idle temp (takes 15-20min). At this time also check to see if the fan activates. If you see the temp reach mid way and the fan isnt activating then it could be a few possibilities.
Go try and burp the system and tell me what you find then we can go from there. PM me and I will go over a few other things
Old Nov 19, 2007 | 12:23 PM
EFLS89's Avatar
what he said
Old Nov 19, 2007 | 06:17 PM
it blows white smoke wen i start it sumtimes ..
Old Nov 19, 2007 | 06:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeEpxiTxLiTt &raquo;</TD></TR><TR><TD CLASS="quote">it blows white smoke wen i start it sumtimes .. </TD></TR></TABLE>
If that is the case the next thing I would do is run a compression test. Have you changed the oil recently? Did you find the oil to be milky or light brown in color?
opg5009
Jun 11, 2007 08:40 AM
TBoe
15
Jul 31, 2005 01:56 PM
tianporn
Jun 18, 2005 07:22 PM
EGhatched
Mar 14, 2004 04:17 PM
.nate
Nov 9, 2001 02:41 PM
