which way are the pistons supposed to face?
Old Nov 17, 2007 | 12:20 PM
Kraz13's Avatar
Default which way are the pistons supposed to face?
Im putting togheter my gsr all motor but i got confused. I thought that the engravings on the pistons are supposed to face the exhaust/front of motor. But the valve reliefs on them are bigger on the exhaust side (where the valves are smaller) and the smaller cutouts on the intake (where there is more lift and bigger valves).
Here is a pic to show what i mean. Anyone wanna help?
I feel stupid but i rather know now than when the valves bend to ****.
Old Nov 17, 2007 | 12:54 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: which way are the pistons supposed to face? (Kraz13)
Check the rod bearing tangs, they should be on the exhaust side.
I think you have the pistons reversed.
Old Nov 17, 2007 | 01:04 PM
jcvelez360's Avatar
the biger holes facing the intake side, i think the pistons are reversed
Old Nov 17, 2007 | 01:57 PM
DonF's Avatar
Default Re: (jcvelez360)
They are backwards. Check the tang to EX as MAR said, your may have to rotate on the rods. I would also take a small file and clean all the machined edges, that stuff gets in the water and oil.
Old Nov 17, 2007 | 02:11 PM
Kraz13's Avatar
Thanks guys, i guess its time to go switch them around. I don't know why but when i was putting them on i thought the engraving was supposed to face the front and didn't pay attention to the cutouts.
Thanks.
Old Nov 17, 2007 | 06:30 PM
night's Avatar
Default Re: (Kraz13)
also just go by the cylinder wall squirter in the rod if using stock.
not that they couldn't be on the rod wrong.
Old Nov 17, 2007 | 06:33 PM
Kraz13's Avatar
they were on wrong . I just switched them around and now its all good.
Old Nov 17, 2007 | 07:14 PM
b19coupe's Avatar
At least you asked rather than putting the motor together and running it
Good on ya' mate!
Old Nov 17, 2007 | 09:08 PM
Fat Head
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jcvelez360 &raquo;</TD></TR><TR><TD CLASS="quote">the biger holes facing the intake side, i think the pistons are reversed</TD></TR></TABLE>
Old Nov 17, 2007 | 10:10 PM
ToeJam's Avatar
Default Re: (Fat Head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Head &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
jcvelez360 is right. intake valves are larger..
Old Nov 18, 2007 | 04:34 AM
b20beast978's Avatar
luckily you noticed before it was too late!
1A4
Mar 28, 2008 01:18 PM
gs1gsr
Jan 9, 2008 09:30 PM
mrDFWmechanic
Nov 21, 2004 06:58 PM
mitsuman
Oct 7, 2004 06:17 AM
smokinsi
Jul 25, 2004 05:51 AM
