changing coolant..
Old Nov 15, 2007 | 09:33 PM
Tuesdaynightfever's Avatar
Default changing coolant..
Just making sure I am not missing any steps on my upcoming coolant change. 2000 Civic Cx d16y7.
1) turn car off, let engine cool
2) pop radiator cap, pull radiator drain plug, drain coolant into container
3) put drain plug back in, fill with distilled water
4) turn motor on, heat on high (no a/c, car, defrost buttons) for 10 minutes
5) turn car off, let motor cool, drain water into container
6) replace drain plug, fill with Prestone or Shellzone 50/50 until full
7) turn car on, put heat on high (no a/c, car button, defrost) for 15 minutes
Am I missing anything? Any suggestions would be greatly appreciated.
Old Nov 15, 2007 | 10:28 PM
Projekt_2nr's Avatar
Default Re: changing coolant.. (Tuesdaynightfever)
Old Nov 15, 2007 | 10:30 PM
Hardedge's Avatar
Turn the heater **** all the way over before draining.
Old Nov 15, 2007 | 11:38 PM
AWD: Jeff's Avatar
Default Re: (Hardedge)
is it necessary to turn it on? I took out my heater box. i guess just as long as the radiator fan turns on?
Old Nov 16, 2007 | 03:09 AM
m735is's Avatar
Default Re: (AWD: Jeff)
You just turn your heat on so that the coolant flows through the heater core to get out any air or old coolant, so if you don't have a heater core, this doesn't apply.
Full flush would also include draining the block, although when I replace radiator this weekend, I probably wont, as the coolant is only a few months old.
Old Nov 16, 2007 | 09:19 AM
Default Re: (m735is)
So I don't turn my engine on, just put the key to aux. setting?
MrViet
Oct 20, 2009 09:43 PM
ej1love
10
Jul 21, 2009 11:22 AM
KHowe
Jul 21, 2008 11:02 AM
return_2020
14
Oct 19, 2005 09:23 PM
magic hat #9
Sep 4, 2002 12:39 PM
