my turbo build.Advice on piston & rod setup
Old Nov 15, 2007 | 05:12 PM
hedtrip's Avatar
Default my turbo build.Advice on piston & rod setup
ok im planing on doing a mild turbo build on my d16y8. & thinking about going with some Vetara low comp pistons. & some tunertoys Rods
http://tunertoys.zoovy.com/pro....html
Do i have to shave my girdle & block for these rods like u do for eagles?
& should a bore or hone my block a lil & go with a slightly bigger piston? 75.5mm?
& kinda new to this. never built a block be4
& any other advice would be great
Old Nov 15, 2007 | 05:25 PM
yakuza's Avatar
Default Re: my turbo build.Advice on piston & rod setup (hedtrip)
Before someone else says it to you. Search and read, your requirment depends on your target like someone said 'a sucessful journey begins with knowing the destination'.
Old Nov 15, 2007 | 06:21 PM
buster0371's Avatar
TATS RIGHT. i went with weisico pistons and eagle rods!
Old Nov 15, 2007 | 07:53 PM
HAMOTORSPORTS's Avatar
Default Re: (buster0371)
can't say much about the rods as I don't personally have any experience with them, however, I would recommend always a fresh bore to next size over and hone when rebuilding to ensure a good ring seal and accurate piston to wall clearances. Good luck with the build
Old Nov 15, 2007 | 09:32 PM
buster0371's Avatar
dont bore if your going turbo. especially if your putting in pistons and rods. you want as much meat on those sleeves as possable. so you can push 400whp
Old Nov 16, 2007 | 03:21 AM
hedtrip's Avatar
i think im just gunna go with a good hone. im not aiming for high HP just around 250-300. my current setup im at 179
Old Nov 16, 2007 | 08:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buster0371 &raquo;</TD></TR><TR><TD CLASS="quote">dont bore if your going turbo. especially if your putting in pistons and rods. you want as much meat on those sleeves as possable. so you can push 400whp</TD></TR></TABLE>
good ring seal and accurate ptw clearance is more important than .25mm extra cylinder wall thickness
Old Nov 16, 2007 | 08:46 AM
Schister66's Avatar
Man U FTW
Default Re: (HAMOTORSPORTSUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HAMOTORSPORTSUSA &raquo;</TD></TR><TR><TD CLASS="quote">
good ring seal and accurate ptw clearance is more important than .25mm extra cylinder wall thickness</TD></TR></TABLE>
i second that...if you're running an 81mm bore and the engine has a few miles on it, it is worth your money to get it overbored to 81.5mm. Having a fresh bore and perfectly round cylinder walls is much more important than .5mm more meat on the sleeves
93delsolJDM
Feb 13, 2011 11:25 PM
92lxsleeper
Jan 22, 2011 11:44 AM
VTEC_PRODUCTION
Feb 4, 2009 12:25 PM
ptsaurus
Mar 20, 2004 05:33 PM
GRIMEY.STREET.RACER
Jan 6, 2003 06:00 AM
