having body shop rocker/quater section
Old rusted rocker.
i am having a body shop install a section of my rocker/quarter panel skin. i picked up the following section from my local pick your parts. i'm trying to do most of the prep for to cut cost down. 200 bucks installed. is this sound about right? here is what i have so far does this look okay to you guys?
drilled out all spot welds with a 1/4 stepping drill bit
Step 1.) Center Punched and slight opened up with a 1/8 bit. This way when i use the 1/4 drill bit things will go smoothly, and not bounce out of the hole
Step 2.)Started to drill out spot welds with a stepper bit to 1/4 holes
Step 3.)All upper holes have been drilled out.
Modified by dem0nk1d at 5:35 AM 11/15/2007
Modified by dem0nk1d at 10:08 AM 11/15/2007
Modified by dem0nk1d at 10:12 AM 11/15/2007
Modified by dem0nk1d at 10:14 AM 11/15/2007
Modified by dem0nk1d at 7:53 PM 11/18/2007
200 bucks installed sounds crazy cheap for that. It would come out to like 5 hours labor. I wouldnt install a used rocker section and quarter skin for that price. Spot welds look good though. Are they painting this for your as well? If so u can start to prep your piece by removing stickers and sanding everything down with 150 grit dry sand paper.
i used a 1/4 hole but seems like the peace still doesn't want to remove from the inner metal. hmmm im going to talk to them today. they should do the body work to it. or even if they just install it i can do the filler work.
The pieces areent just going to come apart. U will have to go inbetween the pieces with something about as thin as a putty knife. Beat it with a hammer and it should slowly but surely start seperating, as long as u got through all the weld that is.
Well sorry I didn't align the pictures up in the following steps. I re-edited the post. Everything should make sense now. Thanks for all the help. Just wanted to know if i was doing everything correctly. The hammer and flat paint scraper is a great idea.
Modified by dem0nk1d at 10:16 AM 11/15/2007
oh i'm going to be buying a gal of some descent epoxy primer. check it out...
Kustom Shop KEP -DTM Epoxy Primer / Seal
http://www.tcpglobal.com/kusto....aspx
guy quoted me 100 bucks for the KIT as you see above.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d »</TD></TR><TR><TD CLASS="quote">oh i'm going to be buying a gal of some descent epoxy primer. check it out...
Wait, you are buying the paint? can't your body shop do that or are you planning on priming it for them?
well i'm going to do my own paint job soon. but for now i want to do all the body work and prime the car with a nice epoxy primer. which i'm going to do myself. plus i don't want my car to rust again.
went to the bodyshop today they had the new peace welded in. i guess it's easier to braise the metal than to mig... i will post pictures of the final work. also posted pictures on top of the rust area.
in the rusted pic you can see a not so stock weld. I guess it had damage along time ago before i owned the car. i will be picking the car today... posting new pictures.
hondaon18's
12
Apr 7, 2009 02:57 PM
