b20/vtec turbo people
Old Jun 24, 2002 | 11:17 AM
ezark's Avatar
Default b20/vtec turbo people
where did you hook your oil sender line to on the block?
Old Jun 24, 2002 | 11:27 AM
CovertFI's Avatar
Default Re: b20/vtec turbo people (gsR-T mode)
i have heard some people getting their oil supply line from the vtec solenoid so i would imagine that you could run the sending line to there.
Old Jun 24, 2002 | 12:21 PM
djdxm's Avatar
I just T'd mine off the back.. makes a huge cluster of T's on the backof the block. I am going to run a line from the block to the T's to relieve the pressure off the block. I am still thinkin about the Z10 oil pump adapter.
-jay
[Modified by djdxm, 9:24 PM 6/24/2002]
Old Jun 24, 2002 | 12:29 PM
FOrSfEd's Avatar
Default Re: b20/vtec turbo people (djdxm)
Yeap thats where I ran mine, don't use the vtec sender, you won't get enough oil flow for the turbo.
Lee
Old Jun 24, 2002 | 01:58 PM
ezark's Avatar
Default Re: b20/vtec turbo people (Rex2nv)
where would you find the fitting to do that at the bottom of the block? any part #?
Old Jun 24, 2002 | 02:24 PM
SlowB16's Avatar
I think it is 1/8" BPT. Not sure though. But you will need one that is a tee....go to a hydrolic pump store, or a plumbing supply store
Old Jun 24, 2002 | 05:00 PM
Pelican's Avatar
Default Re: b20/vtec turbo people (SlowB16)
Awesome, I have tried to seach everywhere for hybrids w/ turbos for this exact question. Because the same works for a lsvtec. I was wondering if it was too much of a strain there, if the pressure would still be alright.
Thanks for posting
Old Jun 24, 2002 | 05:27 PM
djdxm's Avatar
Default Re: b20/vtec turbo people (Pelican)
I dont think the strain is too much due to pressure, when i mean strain i ment strain on the threads for havin all this extra weight hanging out of them with all the hoses and such. And the movement. I have been using it for quite a while and haven't had a problem yet. It doesn't even leak.
-jay
[Modified by djdxm, 2:28 AM 6/25/2002]
Old Jun 24, 2002 | 07:41 PM
ezark's Avatar
in that case, wouldn't the VTEC solenoid be a suitable place for oil tap? also the oil will have to travel less, and wouldn't have to be split off in so many different directions. i've been running it from the VTEC solenoid for 5-6 months now.. no problem.
mxglory258
Sep 12, 2008 04:42 AM
clemsonhatch
Feb 8, 2005 10:19 AM
. o 69 o .
Feb 7, 2002 08:48 AM
HX_Guy
Dec 25, 2001 08:21 AM
HX_Guy
Dec 24, 2001 11:03 PM
