Oil consumption issue
Old Nov 14, 2007 | 02:02 PM
sweck's Avatar
Default Oil consumption issue
Hey guys, I don't really post up much here, as i'm more of a DSMer (srwd talon), but I just purchased a honda and could use some of your input.
I recently purchased a 97' Honda Prelude and it's having a weird oil consumption issue.
At startup, idle, or when crusing around at part throttle, it doesn't smoke at all. Even if i'm going around at like 3/4 throttle, no smoke. However, if I give it enough pedal to have it downshift, (yes I bought an auto) and stay on the throttle, it smokes like a TRAIN!
So it seems like it only smokes in higher RPMs and under load.
Basically i'm just confused on why there is such a drastic change from no smoke to TONS of smoke. I thought maybe the valvestems at first, but wouldnt it smoke on startup and cruise as well? I did a compression test when I first purchased the car (dont recall #s, they were relatively high though), and they were all consistant, so I know its not a HG.
I'm not much of a honda guy so any input would be helpful! Not sure if it has anything to do with the vtec engagement or anything?...
What should my compression numbers be? It's a stock bottom end and factory headgasket.
Thanks in advance!
Old Nov 14, 2007 | 02:06 PM
Jago's Avatar
Default Re: Oil consumption issue (sweck)
you will need to perform a leakdown and compression test.
Old Nov 14, 2007 | 02:13 PM
sweck's Avatar
Default Re: Oil consumption issue (Jago)
I'll do a compression test again and post the specific numbers once I get home tonight, but IIRC doesn't a leakdown only really tell you if you have a bent valve or a valve that isnt seating well? From my understanding that really wouldn't have much to do with oil consumption?
Old Nov 14, 2007 | 02:14 PM
nonvteclude's Avatar
mine was doing the same thing. with a compression/leakdown test i discovered it was valve seals. replaced them and its all gone now.
Old Nov 14, 2007 | 02:16 PM
sweck's Avatar
Default Re: Oil consumption issue (nonvteclude)
huh, weird, I guess i'll go ahead and do a leakdown at work tomorrow. Thanks.
Old Nov 14, 2007 | 02:25 PM
mattsnooz's Avatar
welcome to world of honda!
word of advice, ditch that auto tranny b4 it ditches you.
The smoke is black right?
compression should be around 200 across I thought??? depending on type of compession test too. I believe theres more than one type of compression test.
Hows the valve train noise? could a valve adjustment help anybody think? if it hasn't been done in a while and is ticking.
Old Nov 14, 2007 | 02:34 PM
vinuneuro's Avatar
Default Re: Oil consumption issue (mattsnooz)
Sounds like bad oil control rings.
Old Nov 14, 2007 | 02:39 PM
sweck's Avatar
Default Re: Oil consumption issue (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattsnooz &raquo;</TD></TR><TR><TD CLASS="quote">welcome to world of honda!
Hows the valve train noise? could a valve adjustment help anybody think? if it hasn't been done in a while and is ticking.</TD></TR></TABLE>
Yeah i've heard that about the auto, but I already have a spare, and figured if it would just be my unmodded daily driver, i'd be ok. I guess i'll find out
As far as compression goes, it'll read a little lower up here (5800ft) but IIRC it was tapping somewhere in the high 180s across on the gauge last time I did it, i'll do it again here soon.
The smoke is black/dark greyish with a little blue. Its bad! In the past everytime i've seen mass oil consumption it's been strictly almost all blue (bad turbo, bad hg, too much case pressure, etc...)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like bad oil control rings.</TD></TR></TABLE>
Didn't really think about that, you think its possible that when oil pressure increases (high rpms/high load), that its pushing past the rings? or maybe thats the case with the seals? (never had a car with vtec/mivec/vvtc before this, so not sure if bad seals have other symptoms on these motors)
Thanks for the input guys!
Old Nov 14, 2007 | 02:44 PM
mattsnooz's Avatar
Oh...your hitting vtec?....that explains it. Yes it could push past the seals
separate question all together, does your motor tick while idling?
that compression is *okay (180)
Old Nov 14, 2007 | 03:23 PM
vinuneuro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sweck &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks for the input guys! </TD></TR></TABLE>
Bad valve seals will show themselves after vacuum conditions, after you've been idling a long time and then start moving, or high-rpm off-throttle then back on.
On-throttle without vacuum like your situation indicates bad oil-control rings.
gabriel0830
13
Dec 18, 2012 09:22 PM
Honda Sport
Mar 13, 2008 06:01 PM
M.A.R.C.
Feb 22, 2006 12:42 PM
one slow coupe
Jan 31, 2006 06:24 AM
Civicman86
Sep 15, 2005 07:27 AM
