Need expert help. Loosing oil, I have a few scenarios of where it is going...
Well I am still trying to diagnose where I am loosing oil at. Before you say rings or seals read the rest of this. If you have any help please let me know.
First I noticed (or it seemed that I loose more oil in the winter months) This might just be coincidence but I did notice it.
I have also noticed that I can smell blow by when deaccelerating on the freeway (ie no throttle). As soon as I get back on the throttle the smell goes away. Let back off and most the time you can smell it again.
Late one night last week I was out practing my launches on a deserted street. Noticed that when I used the full throttle launch feature that I could see smoke coming out from under the hood. I am guessing this is coming out of the breather vavle?
I have done a compression and leakdown test. My compression was about 200 across the board. They weere a little off but no more than like 10% of each other. I also did a leakdown test and none of the cyl showed more then 6% leak.
I have switched from 5w-30 to 10w-30 mobile one. Its really bothering me. I might loose 1/8 quart a week. Sometimes I wont need to fill any, sometimes I will need to top it off.
TIA
TIA
Re: (Civicman86)
your for sure burning it? how do you know.
are you sure its not leaking out somewhere
get some dye and add it to your oil. get a black light and look for leaks.
platinum.
platinum.
Re: (platinum00)
I have never left a spot of oil anywhere. I can smeel the oil burning on the freeway too. Its really starting to irritate me
Re: Need expert help. Loosing oil, I have a few scenarios of where it is going... (Civicman86)
Good compression and a burning smell on decelleration sounds like a turbo seal problem or a valve seal problem. Both when there is a vac on the system pulls oil through the seals. Do you have oil in your charge or intake pipes coming off the turbo?
Re: Need expert help. Loosing oil, I have a few scenarios of where it is going... (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">Good compression and a burning smell on decelleration sounds like a turbo seal problem or a valve seal problem. Both when there is a vac on the system pulls oil through the seals. Do you have oil in your charge or intake pipes coming off the turbo? </TD></TR></TABLE>
It must be the valve seals then. This problem was going on before boost.
Thanks for the help guys. Im just gunna say im 99% sure its the valve seal.
bigslimdog
42
03-27-2004 03:02 PM
TheHater
11
12-26-2002 07:00 AM
