bouncy idle
Old Nov 13, 2007 | 09:25 PM
usdmEHboy's Avatar
Default bouncy idle
When at a light, the idle on my b16 goes up and down from like 1000-1300...it's kind of annoying. I'm not throwing any codes so i have no idea what it is
Old Nov 13, 2007 | 10:35 PM
EG8R's Avatar
Default Re: bouncy idle (usdmEHboy)
possibly iacv failing. also check your coolant level.
Old Nov 13, 2007 | 10:44 PM
spenny's Avatar
Default Re: bouncy idle (EG8R)
could be the IAT as well
Old Nov 14, 2007 | 05:39 AM
crazyguy's Avatar
did u just complete the b16a swap? are u running p30 ecu ?
Old Nov 14, 2007 | 05:55 AM
igotnothin's Avatar
i just got done fixing this issue.
You can check if its the icv just by unpluging it after warm up. If your car idles right, it is going bad or just needs to be cleaned. mine went bad so i just bypassed it. I tired to clean it, but it didnt help.
to clean just remove it and spray some break cleaner in there till it stops coming out black. typicaly its the side with the screen thats the issue, but do both.
Iat can do it to, but typicaly not the issue. Other problems can be you timing, valve lash, and your idle screw could be to high.
Old Nov 14, 2007 | 08:58 AM
usdmEHboy's Avatar
Default Re: bouncy idle (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">did u just complete the b16a swap? are u running p30 ecu ?</TD></TR></TABLE>
i did the swap like 6 months ago and it's been like that since then..o yea i am running a p30
Old Nov 14, 2007 | 09:10 AM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdmEHboy &raquo;</TD></TR><TR><TD CLASS="quote">
i did the swap like 6 months ago and it's been like that since then..o yea i am running a p30</TD></TR></TABLE>
yeah thats the reason i ask..cause it did the same thing to me..p30 ecu didnt make my car idel or run smooth..i switched to chipped p28 ecu and it is been perfect since the day i switched a chipped p28
Old Nov 14, 2007 | 09:12 AM
usdmEHboy's Avatar
hmm good to know...quick question...the iacv is under the throttle body right? what about the iat...is that the one on top of the manifold..i forgot
Old Nov 14, 2007 | 09:52 AM
BUDtoker's Avatar
Old Nov 14, 2007 | 10:11 AM
black_EM1's Avatar
Community Builder
Community Influencer
It's almost directly behind it. There's a picture on here somewhere, I don't remember where.
It's the thing on the back of the intake manifold, sorry I can't be more descriptive.
Old Nov 14, 2007 | 10:21 AM
Panda Eg6's Avatar
Default Re: bouncy idle (black_EM1)
yea it is right behind the intake manifold, it will have one sensor on it and two hoses comming off it if that helps lol!
drock305
Nov 7, 2007 06:56 PM
alghafat424
Nov 13, 2006 01:29 AM
guywitaDA
Dec 29, 2005 11:05 AM
JPsprintCIVIC
Jul 23, 2004 05:17 AM
Bigjussin
Mar 3, 2004 07:06 PM
