GSR Rod Discoloration???
Old Nov 13, 2007 | 05:14 PM
B18C_EJ8's Avatar
Default GSR Rod Discoloration???
What would cause this? Just the heat of an all-motor, high-compression setup?
Anything to be really concerned about??
Old Nov 13, 2007 | 05:18 PM
Aquafina's Avatar
I wouldn't use it.
Old Nov 13, 2007 | 05:24 PM
B18C_EJ8's Avatar
Any particular reason why?
Old Nov 13, 2007 | 05:27 PM
Aquafina's Avatar
Default Re: (B18C_EJ8)
It had obviously gotten hot. google what heating metal up does.
When some idiot torches a rod to get the pin in or out, thats what it looks like. So that rod got hot.
If in doubt, throw it out.
Old Nov 13, 2007 | 05:57 PM
quicksilver1689's Avatar
i ♥ snails
yeah metals can/do get weaker if there heated to really high temps. would you call this annealing or is it a process or hardening/chancing properties of metal or would annealing make metal more soft or ductile?
Old Nov 14, 2007 | 04:28 AM
NJIN BUILDR's Avatar
Default Re: GSR Rod Discoloration??? (B18C_EJ8)
If that's a floating pin rod than you have a problem.If it's a press fit rod than don't worry about it.Whoever heated it to install the pin got a little carried away.I have seen hundreds of rods that look like that and none of them failed.
Old Nov 14, 2007 | 04:54 AM
B18C_EJ8's Avatar
Default Re: GSR Rod Discoloration??? (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">If that's a floating pin rod than you have a problem.If it's a press fit rod than don't worry about it.Whoever heated it to install the pin got a little carried away.I have seen hundreds of rods that look like that and none of them failed.</TD></TR></TABLE>
The rod is attached to an Endyn Rollerwave, which I believe are press fit... The piston doesn't move on the pin at all...
Old Nov 14, 2007 | 04:58 AM
Furyof4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
The rod is attached to an Endyn Rollerwave, which I believe are press fit... The piston doesn't move on the pin at all... </TD></TR></TABLE>
That's a problem, the rod is press fit onto the pin not the piston. The piston weather stock or forged should move freely on the pin.
Old Nov 14, 2007 | 05:06 AM
B18C_EJ8's Avatar
Default Re: GSR Rod Discoloration??? (Furyof4)
I meant that it doesn't move side to side at all, but now I'm confused... I'll have to check them out when I get home...
Old Nov 14, 2007 | 05:11 AM
Furyof4's Avatar
Oh that's ok, the rollerwaves have circlips at each end of the pin which would limit side-to-side movement. Does the piston rotate on the pin?
Old Nov 14, 2007 | 05:34 AM
B18C_EJ8's Avatar
The piston pivots forwards & backwards freely, I just don't know if the piston is moving on the pin or if the pin is moving in the rod...
I'll have to look closer tonight...
Old Nov 14, 2007 | 04:16 PM
mtber's Avatar
That is not normal. Replace it..
Old Nov 14, 2007 | 04:50 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Furyof4 &raquo;</TD></TR><TR><TD CLASS="quote">Does the piston rotate on the pin?</TD></TR></TABLE>
Yes.
Old Nov 14, 2007 | 06:09 PM
cartune network's Avatar
get rid of it. and dont use that machinist again ever.
Old Nov 14, 2007 | 06:49 PM
Runnerdown's Avatar
Default Re: GSR Rod Discoloration??? (cartune network)
They heat up the small end rather then press the pin. I have seen countless rods like that with no problems. I heat them up too, but not to the point that it discolors the rod....
Old Nov 14, 2007 | 09:04 PM
And make sure they didn't also put the clips/locks in.Like i said ,I have seen hundreds of rods assembled that looked that with no problems.It was done with a torch most likely and not an electric rod heater.I have seen people also use the spiroloxs and that usually ruins the rods or cranks if the pins weren't perfectly centered.
turboef90
Oct 11, 2013 04:38 AM
RootBur
Jan 27, 2012 04:26 PM
geebs
May 17, 2007 10:41 AM
2point2
Jun 29, 2004 02:29 PM
boosted3g
Jan 15, 2003 04:48 PM
