valves
Old Nov 13, 2007 | 12:05 PM
Del Sol Hatch's Avatar
Default valves
do you know where i can find valves? and how many do i get for a D16Z6 ? is it worth it to replace? How much would it be? i dont hav the money right now to buy a new motor though im trying to look into it? any advice on thAT like where to look?
Old Nov 13, 2007 | 12:06 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: valves (Del Sol Hatch)
This can only end poorly.
It's a 16 vavle motor.
Why would you need to replace them?
What are you doing with the motor?
What mods do yo have?
Old Nov 13, 2007 | 12:11 PM
Default Re: valves (***$nyper)
i haven't moded anything yet. the mechanic that put it in my 91 dx hatch never checked the timing belt when he put in the engine and around 120000 miles it broke..a couple of the valves bent a little he said...the car runs and is smooth after about 2000 rpms but i need to replace the valves before it blows right now it just has a rough idle
Old Nov 13, 2007 | 12:14 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Sol Hatch &raquo;</TD></TR><TR><TD CLASS="quote">i haven't moded anything yet. the mechanic that put it in my 91 dx hatch never checked the timing belt when he put in the engine and around 120000 miles it broke..a couple of the valves bent a little he said...the car runs and is smooth after about 2000 rpms but i need to replace the valves before it blows right now it just has a rough idle</TD></TR></TABLE> unless you want to work on it yourself or mod the head probbly best to just get another head.
I'd be happy to help you either if you want to fix the valves in this head or get another. What will work best for you is up to you.
Old Nov 13, 2007 | 12:19 PM
Well, i live in Maryland and i realize most people on here live in California. Is it hard to do on your own? I am learning this stuff as i go i built the car from the body up. It's a del sol in a hatch body. A mechanic put the engine in but i had to do all the inside and all. I've learned a lot and so far found success. Everything would be fine is the mechanic wasn't an idiot. Anyways, how much would a new head cost and is that all i need? the head? do u kno someplace i can find it?
Old Nov 13, 2007 | 12:22 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Sol Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Well, i live in Maryland and i realize most people on here live in California. Is it hard to do on your own? I am learning this stuff as i go i built the car from the body up. It's a del sol in a hatch body. A mechanic put the engine in but i had to do all the inside and all. I've learned a lot and so far found success. Everything would be fine is the mechanic wasn't an idiot. Anyways, how much would a new head cost and is that all i need? the head? do u kno someplace i can find it?</TD></TR></TABLE> There are a bunch of east coasters, myself included.
Are you in a rush or no? If you arn't build the head yourself and learn
A new z6 head wont be more then 250 complete. You can get them in the marketplace.
Old Nov 13, 2007 | 12:38 PM
the problem with building the head is that i dont kno wat parts i need...only thing i kno is wrong wit it is the valves but i kno ill end up needing more than that...and i was planning on waiting til after winter cuz i worked on the car al last winter and then it broke down this summer which blew *****
Old Nov 13, 2007 | 12:40 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Sol Hatch &raquo;</TD></TR><TR><TD CLASS="quote">the problem with building the head is that i dont kno wat parts i need...only thing i kno is wrong wit it is the valves but i kno ill end up needing more than that...and i was planning on waiting til after winter cuz i worked on the car al last winter and then it broke down this summer which blew *****</TD></TR></TABLE> Well take it to someone who knows better and find out, that's your first step.
if you are looking at just a stock rebuild do that if you want to add power or mods it's great time to do it.
Old Nov 13, 2007 | 12:45 PM
can't i put another head on and get more power that way? do u kno other heads i can switch to that would be a good idea? i kno d series isn't as good as a b series in horse power and all but i cant afford a whole new engine
Old Nov 13, 2007 | 12:46 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote"> Well take it to someone who knows better and find out, that's your first step.
Aww Max, you're such a nice guy.
To the OP, i'd really recommend taking some time to learn about your cylinder head. you can do most things yourself with some simple and inexpensive hand tools if it is salvageable. this will help you diagnose any further issues you might have with it as well as give you a much better understanding of whats going on up there. The only thing you'd have to pay a machine shop for is to mill it ( make the surface where the cylinder head meets the block true and flat for proper sealing ). You can do 95% of the work yourself tho... dseries.org should be able to help a bit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Sol Hatch &raquo;</TD></TR><TR><TD CLASS="quote">can't i put another head on and get more power that way? do u kno other heads i can switch to that would be a good idea? i kno d series isn't as good as a b series in horse power and all but i cant afford a whole new engine</TD></TR></TABLE>
You have one of the more desirable D cylinder heads. Just clean it up and get it running like new, thats the best way to go IMO.
Old Nov 13, 2007 | 12:50 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Sol Hatch &raquo;</TD></TR><TR><TD CLASS="quote">can't i put another head on and get more power that way? do u kno other heads i can switch to that would be a good idea? i kno d series isn't as good as a b series in horse power and all but i cant afford a whole new engine</TD></TR></TABLE>Not really, the z6 is prettty much the best D head you can do.
If you want more power out of it, a cam head work and valve train is in order.
All depends how much $$ you have to play with.
You could swap to a y8 head but I'd say keep a z6 if you are going to stay D even if your head is shot get another z6 imo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComeOnKip &raquo;</TD></TR><TR><TD CLASS="quote">
To the OP, i'd really recommend taking some time to learn about your cylinder head. you can do most things yourself with some simple and inexpensive hand tools. this will help you diagnose any further issues you might have with it as well as give you a much better understanding of whats going on up there. The only thing you'd have to pay a machine shop for is to mill it ( make the surface where the cylinder head meets the block true and flat for proper sealing ). You can do 9% of the work yourself tho... dseries.org should be able to help a bit </TD></TR></TABLE> I can be nice when people have a brain and are respectful, so yea rarely
BTW good post
Old Nov 13, 2007 | 12:52 PM
ComeOnKip's Avatar
Try ....
....tis my b-day
Old Nov 13, 2007 | 12:53 PM
Default Re: valves (ComeOnKip)
u mean rebuild what i have instead of buying a new head and getting that one hooked up?
Old Nov 13, 2007 | 12:54 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComeOnKip &raquo;</TD></TR><TR><TD CLASS="quote">Try ....
....tis my b-day </TD></TR></TABLE> Happy bday man
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Sol Hatch &raquo;</TD></TR><TR><TD CLASS="quote">u mean rebuild what i have instead of buying a new head and getting that one hooked up? </TD></TR></TABLE> Yes, you can do that probbly for less money and you'll learn.
also with the head off it's perfect time for some mods if you want or just stock stuff.
07crf250
Jan 14, 2008 07:04 PM
Del Sol Hatch
Nov 11, 2007 04:55 PM
misha
15
Nov 12, 2006 02:16 PM
EKB18BPR3
May 31, 2004 02:34 PM
Redline130
Aug 13, 2001 10:09 PM
