Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Scam or legit service?
Old Nov 12, 2007 | 09:10 PM
fongyz22's Avatar
Default Scam or legit service?
http://madison.craigslist.org/aos/475602485.html
I was thinking if I should go to them for my input shaft bearings and throwout bearings replacement?
I want to avoid dealerships....
- I have the parts for replacing those two things, but don't know where to go for cheap...
***If there is a DIY somewhere...let me know!*** 4day break coming up!
Old Nov 12, 2007 | 10:54 PM
tunerkid7's Avatar
Default Re: Scam or legit service? (fongyz22)
dude its craigslist, thats all i have to say about it, theres some good stuff on there, but about 80% of the stuff is ****
Old Nov 12, 2007 | 11:09 PM
horchata's Avatar
throwout bearing is a piece of cake, honestly. input shaft is a little more indepth but not bad. you could do the throwout without taking the tranny out of the car.
Old Nov 13, 2007 | 05:41 AM
CrazycakesEM2's Avatar
Default Re: (horchata)
Anyone have a DIY on the throwout bearing mine is making a dragging noise with the clutch engaged in neutral
Old Nov 13, 2007 | 06:18 AM
rleonekc's Avatar
Default Re: (CrazycakesEM2)
throughout bearing is simple, i mean, the hard part is...you can't replace it without pulling the engine/axles--to get the the tranny
Old Nov 13, 2007 | 05:18 PM
fongyz22's Avatar
Default Re: (rleonekc)
When it comes to the input shaft and throwout bearings I would not be able to help you. I don't have access to a lift and transmission repairs I would want a lift for that. I could recommend you to a fair shop if you would like. When it comes to the timing belt water pump I can help you there. I did some research and this repair for your vehicle would be 325. The valve cover gasket set is a special order item and would take 3-4 days to receive. The 325 does include ALL parts and labor. I have performed this task on numerous vehicles like yours. I would need to do this at my house being all my equipment is there. I'm located on the west side of Madison and this would take about 4-6 hours. I do work full time so I do repairs usually on Sundays. Hope this helps and I hope to hear from you soon.
Frank V.
that's what he emailed me back on... seems reasonable for the timing belt or no??....
Old Nov 13, 2007 | 05:26 PM
JimmyM86's Avatar
Default Re: (fongyz22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fongyz22 &raquo;</TD></TR><TR><TD CLASS="quote"> I would need to do this at my house being all my equipment is there.</TD></TR></TABLE>
This would make me nervous...
The timing belt/water pump replacement is not THAT hard to do...I'd say breaking the crank pully bolt would be the hardest thing to do.
If you do take it to this guy make sure someone goes with you and keep an eye on him and your car...I don't trust people nowadays
Old Nov 13, 2007 | 06:04 PM
Vermont's Avatar
Default Re: (JimmyM86)
timing belt and water pump are easy. Takes a little muscle and a little thought, had to replace a power steering pump and and the ac on my dads 2000 Dakota. I know they are different vehicle's but it shouldn't be to different. Took me 3-4 hours with a little help from a friend.
I'm mildly retarded so it shouldn't take you long at all man.
Old Nov 13, 2007 | 06:07 PM
JimmyM86's Avatar
Default Re: (Vermont)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vermont &raquo;</TD></TR><TR><TD CLASS="quote">
I'm mildly retarded so it shouldn't take you long at all man. </TD></TR></TABLE>
LOL...If we can do it, then you shouldn't have any worries!
If you decide to DIY, you will be suprised with how easy it actually is!
Old Nov 13, 2007 | 06:50 PM
gsxr1k05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fongyz22 &raquo;</TD></TR><TR><TD CLASS="quote">When it comes to the input shaft and throwout bearings I would not be able to help you. I don't have access to a lift and transmission repairs I would want a lift for that. I could recommend you to a fair shop if you would like. When it comes to the timing belt water pump I can help you there. I did some research and this repair for your vehicle would be 325. The valve cover gasket set is a special order item and would take 3-4 days to receive. The 325 does include ALL parts and labor. I have performed this task on numerous vehicles like yours. I would need to do this at my house being all my equipment is there. I'm located on the west side of Madison and this would take about 4-6 hours. I do work full time so I do repairs usually on Sundays. Hope this helps and I hope to hear from you soon.
Frank V.
that's what he emailed me back on... seems reasonable for the timing belt or no??....</TD></TR></TABLE>
ARE YOU ******* KIDDING ITS A HONDA
you dont need a lift for a trans drop/install. just a jackstand. and on a manual trans you dont even need that. you can benchpress that bitch and put it on. the auto trans would need a jack cause that mother is heavy as ****. but come on..
just pull the axles (you dont even have to remove then from the front forks i dont) drop the trans and change the bearing.
http://hondahookup.com/manuals
register with the site and get the manual you need.
Old Nov 13, 2007 | 07:17 PM
Curiouz_G's Avatar
he didnt say he COULDNT. he said he WOULD WANT. big difference.
Old Nov 13, 2007 | 09:14 PM
fongyz22's Avatar
Default Re: (Curiouz_G)
well looks like that honda site for manuals doesn't have the EM2 service manual :X oh well....still looking and poking around for any DIY to keep me busy this upcoming 4-day turkey break
r.f.b
13
Nov 2, 2017 06:45 AM
MTracing
Transmission & Drivetrain
Dec 18, 2011 06:42 AM
JDM_SOHC
May 26, 2006 07:45 AM
88 rex
Apr 2, 2006 07:23 AM
vg7z
14
Jul 23, 2005 06:33 AM
