Base Map
Old Nov 12, 2007 | 03:08 PM
wernhersey's Avatar
Default Base Map
Can anyone tell me where I can send my ecu to get a basemap tune. I have searched a little bit and couldn't find anything in the Mass. area. Thanks
Old Nov 12, 2007 | 03:13 PM
arc_55's Avatar
Default Re: Base Map (wernhersey)
You need to be more specific about what EMS you are using. I am assuming the more popular programs and also what does your setup consit of?
Old Nov 14, 2007 | 01:47 PM
wernhersey's Avatar
Default Re: Base Map (arc_55)
Im not sure which ecu I am going to use. From what I have read it seems it would be better to convert to obd1 and run a p28. But on the other hand I don't have vtec and I believe that the p28 is a vtec ecu. Anyway, which ecu do you think would be best to run? And I am running a t3/t4 .48/.50, probably 370cc injectors, a walbro 255, and a 27x6.5x2.5 intercooler. My goal is somewhere in the ball park of 250whp. Thanks
Old Nov 14, 2007 | 04:17 PM
mtber's Avatar
Get larger injectors & find your self a local dyno tuner for the best results.
If you plan on running on a basemap, buy your self a wideband oxygen sensor.
Old Nov 15, 2007 | 11:13 AM
wernhersey's Avatar
Default Re: Base Map (mtber)
I have a Dyno here at school but I have never tuned before. I do plan on getting a wideband just to be on the safe side.
sethg
May 4, 2015 05:32 AM
ahenscheid
Jan 30, 2012 10:06 PM
MurtazaDSM
Aug 8, 2009 08:23 AM
QuickDxEk
11
May 31, 2007 01:45 PM
0o_coupe
May 28, 2007 06:58 PM
