Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Ground Control Setups......
Old Jun 24, 2002 | 04:21 AM
VTECAcuraGSR's Avatar
Default Ground Control Setups......
Ok Guys,
i finally got all my parts and the install is going in soon. I was looking at the koni's and the front has 2 rings and back 3. Which should I use to install my ground controls? I have the stock GC rates. I was thinking of lowering the car like 1.5". Is this a good height? The car is daily driven and autocrossed heavily (every other weekend). When I install the koni/GC should I have an alignment? I know when lowering it I will gain some good camber, but wont the toe get knocked out? Is there a easy way to do this myself? I know how to adjust the tie-rods, but how do you measure toe? Thanks!
Old Jun 24, 2002 | 04:37 AM
CivicSiRacer's Avatar
Default Re: Ground Control Setups...... (VTECAcuraGSR)
I recommend using the stock height ring. I think it was the lower on the fronts and middle on the rears. Going too low on Konis (more than 2") can run into problems like me hitting the bumps stops since I was dropped 2.5" DOH!
Old Jun 24, 2002 | 04:46 AM
Neo's Avatar
Neo
Default Re: Ground Control Setups...... (CivicSiRacer)
I agree completely w/ Michael -- use the stock ride height settings on the Konis. Given that you're pairing the Konis w/ GC coilovers, you've got more than enough ride height adjustability there and, consequently, don't need to muck around w/ the Koni perch settings.
Old Jun 24, 2002 | 05:56 AM
AcuraRacer112's Avatar
Default Re: Ground Control Setups...... (Neo)
The car is daily driven and autocrossed heavily (every other weekend). When I install the koni/GC should I have an alignmen?
Mine was fine afterwards, a lil pull to the right, but the car still drove straight for about a half a mile with no hands on it.
Mine only moved very slightly, not enough to really worry about it at this point, I will fix it when I get a machine alignment after I get my camber kit
What rates are those?
I lowered mine an inch in the front and 2 in the rear, 1.5 wont be a bad drop, depends on what kind of tires you are running for clearance issues, and you have a long way before riding on the bump stops come into play. other than that you should be fine
Old Jun 24, 2002 | 08:01 AM
Default Re: Ground Control Setups...... (AcuraRacer112)
I am running the stock 195/55/15 Rims and kuhmo 712's. So rubbing shouldn't be an issue. How low is 1" drop? How many fingers between the tire and fender? I know I can use string and a jig to meaure toe, can anyone elaborate on how to do this? So it sounds like I am going to do a lot of playing to get this setup.... Any more help or ideas is greatly appreciated!
Old Jun 24, 2002 | 08:24 AM
maybe 2 on mine with stock tires and rims (for now)
I had a link to an article on Toe measurement...I will try to find it
Old Jun 24, 2002 | 02:31 PM
Is it advised to have different heights between Front and Back?
Old Jun 24, 2002 | 03:05 PM
travis's Avatar
Maybe. You should set all four corners such that you get good suspension travel, and they you should have the car corner balanced.
Old Jun 24, 2002 | 04:37 PM
Default Re: Ground Control Setups...... (ITR#231)
What constitutes good suspension travel?
Old Jun 24, 2002 | 06:53 PM
A 1" drop is about 2 fingers (or about 1.5" between the fender and the top of the tire). A 2" drop is about 1 finger (or about .75" between the fender and the top of the tire)
Old Jun 24, 2002 | 10:43 PM
satintegra's Avatar
when you say "stock GC rates", are those the limited edition ones?
Old Jun 25, 2002 | 02:18 AM
Default Re: Ground Control Setups...... (satintegra)
No not the limited editon..... I believe the stock Ground control rates are 380F and 250R.
PatrickGSR94
Suspension & Brakes
108
Jan 6, 2026 11:15 AM
bonh
Suspension & Brakes
Sep 28, 2009 05:26 AM
IntegraBoy04
May 13, 2003 05:04 AM
24hourflipness
Apr 4, 2003 08:02 PM
chrisv76
Apr 21, 2002 10:14 PM
