ABS problem, code 42
Old Nov 11, 2007 | 07:35 PM
stiness101's Avatar
Default ABS problem, code 42
Currently I have code 42 for the ABS in my car which means that there is something wrong with the left front wheel sensor. It only comes on after i start rolling like 15 feet after i initially start the car. I checked the gapping between the ring and the ABS sensor and it is outside of spec, but so is the right side sensor and it isn't tripping a code. How can i diagnose to see if the sensor is just not getting any signal? What points can I touch with an ohmmeter and what specs should it be within? BTW the car is a 96. Any help would be really appreciated, thanks!
Old Nov 15, 2007 | 06:36 PM
SEATownboi08's Avatar
Default Re: ABS problem, code 42 (stiness101)
Same thing happened to my integra i compared the pads and the abs light was being thrown because of Frozen Brake Caliper. Put new calipers on and no more abs light
Old Nov 16, 2007 | 03:56 AM
Dogginator's Avatar
Daisy... Daisy...
You need a multimeter. You simply check the sensor resistance. I forget the value, but it is in the Helm manual.
Old Jul 6, 2010 | 03:50 AM
unknownally's Avatar
Could this code also come on because of let's say bad brake pads, warped rotors, or bad wheel bearings? Or is there just something wrong with the sensor?
tobytigger
Jun 23, 2015 04:31 PM
danteisme
Nov 19, 2004 02:29 PM
gsr squirrel
Mar 14, 2003 10:19 AM
Jaisun
Oct 25, 2001 06:47 PM
