Vtec Wiring question
Old Nov 8, 2007 | 09:54 AM
Acidcrakker's Avatar
Default Vtec Wiring question
Im doing the wiring on the Vtec now. Im at the ECu and the place where the Vtec silenoid is supposed to go into A4 already has a wire in there. A3 is open and that is right under neathe it. Should I splice wires or should I Just plug it into A3
Old Nov 8, 2007 | 12:00 PM
Default Re: Vtec Wiring question (Acidcrakker)
Someone any one???
Can you tell me where the Vtec oil Presuure switch and the Solinod are located on the motor, Im having issues with this. I think the Solinod is to the left of the distrubtor, and the oil pressure is on top of the fuel rail
Old Nov 8, 2007 | 12:35 PM
mgags7's Avatar
dude look at the "how to wire vtec" thread.
You do NOT want to plug a wire into the wrong ecu terminal. splice into A4.
Old Nov 8, 2007 | 01:38 PM
LaEzEnT's Avatar
Well, if you splice the wire that was already there then what happens to that wire that you just spliced? You dont need that wire anymore or what? I'm in the processing of wiring vtec myself and that was one of my concern.
I can understand if it was an empty spot so you can plug in the vtec but it's already taken
Old Nov 8, 2007 | 01:55 PM
Default Re: Vtec Wiring question (LaEzEnT)
I dont understand. Its a fuel injector wire. In that spot. Either Im looking at it upside down or IDK. Im going off the digram Cha4trx gave me. I looked in the how to wire the vtec section down. Read it three times, but Im still foggy about it cause this is what I have right now.
<center>
The black circle is the Vtec Solinod, and the red circle is the oil pressure switch?
</center>
Well I have this left over and something else plugged into the vtec oil pressure switch.
Old Nov 8, 2007 | 02:00 PM
Giant_Bean's Avatar
in your first pic, the 1 pin connector circled in black is you solenoid, the other circled in red is your oil pressure switch, which should have 2 wires, one of which should be grounded to the block, don't remember which though.
edit: the thing in the second pick is a purge solenoid for the EGR valve i believe, which on the US preludes is mounted in the firewall, so that is unnecessary.
Old Nov 8, 2007 | 02:10 PM
Default Re: Vtec Wiring question (Giant_Bean)
wow Giant beam to the rescue. I spent the last 3 hours staring at it racking my brain trying to figure out what it is.
Old Nov 8, 2007 | 02:12 PM
Wait that still leaves me with an extra switch. I have it plugged into the Oil presure switch.???
Old Nov 8, 2007 | 02:16 PM
Giant_Bean's Avatar
do you have the temp switch on the thermostat housing plugged in? I believe it uses a similar connector.
Old Nov 8, 2007 | 02:26 PM
Yeah I do its a purple plug. Thought right where the lower radiator hose is. I also have another plug on the chasis that I though matches up. I also have another Green plug that is up where the dizzy plugs are to.
Old Nov 8, 2007 | 02:37 PM
Giant_Bean's Avatar
depending on the year I think some chassis were pre-wired for vtec, which would explain why you have a wire in your ECU already and the extra plug you have I think. somebody correct me if I am wrong there.
Old Nov 8, 2007 | 02:39 PM
No Im pretty sure your right about that, but its the preludes 93 and above. I have the 92.
allsho
Jun 14, 2007 12:06 PM
lsvtecSIrex
Jun 14, 2006 03:13 PM
ilovemyb16a
May 18, 2006 12:58 PM
BluntMan
Jan 3, 2003 09:23 AM
flat-blk-HB
Sep 30, 2002 06:56 PM
