what is this noise?
Old Nov 8, 2007 | 04:29 AM
el_toro_de_magnifico's Avatar
Default what is this noise?
http://smg.photobucket.com/alb...8.flv
happens usually when i start it cold. its the sound you hear 5 seconds into the video. seems to be coming from the intake manifold side. any ideas? wanna get this fixed.
Old Nov 8, 2007 | 04:40 AM
Mitsuzuki's Avatar
Default Re: what is this noise? (el_toro_de_magnifico)
Starting to get cold where you are? Maybe run a lighter weight oil. Sounds like lifter noise.
Old Nov 8, 2007 | 02:14 PM
thanks.
well even if its hot or cold outside it still makes that sound. sometimes even when im running or slowly going up an incline while punching on the gas. what could it be? anyone?
EDIT: will adjust valve clearance to see if anything happens. hpe it gets solved.
Old Nov 8, 2007 | 02:59 PM
bart2546's Avatar
Default Re: (el_toro_de_magnifico)
My 99 EX does the same thing all year long warm or cold. However, it gets worse when the temperatures drop outside and it it sits for a few hours. (E.G. overnight) Once the car warms up and it's actually driven, the sound goes away 98 percent of the time. There is that 2 percent that it does it all the time but honestly, I have not seen any side effects from this. I took my valve cover off and there's no damage or anything like that. Just annoying really. Oh and I almost forgot, I run fully synthetic 5w30 in the car and it does it with that weight and it did it with 10w30 so personally I wouldn't worry.
Old Nov 8, 2007 | 03:43 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by el_toro_de_magnifico &raquo;</TD></TR><TR><TD CLASS="quote">EDIT: will adjust valve clearance to see if anything happens. hpe it gets solved.</TD></TR></TABLE>
Yes, I'd try that first. Make sure the engine is completely cold before doing the adjustment.
Also make sure you're running the proper oil.
jaebekae
24
Feb 19, 2010 04:15 PM
sp00led
Sep 13, 2004 06:09 PM
hatchdrvr
May 27, 2004 01:03 PM
jordan88
10
Feb 24, 2003 03:15 AM
