need help with my speed sensor, reverse, and coolant
Old Nov 6, 2007 | 03:35 PM
rtrsl's Avatar
New User
Default need help with my speed sensor, reverse, and coolant
has anyone had problems w/ their speed sensor and reverse light??? i've changed out the speed sensor...thought it was the wire harness changed that too, still not working...also thermostat won't open w/ motor running hot, but tested w/ boiling water it opens...any suggestions???
Old Nov 6, 2007 | 03:45 PM
blackfoot's Avatar
Default Re: need help with my speed sensor, reverse, and coolant (rtrsl)
for less than 10$ change the thermostat, and as for the no speedo, change your cluster
Old Nov 10, 2007 | 12:05 PM
rtrsl's Avatar
New User
Default Re: need help with my speed sensor, reverse, and coolant (blackfoot)
thanks, come to find out it wasn't the thermostat but radiator cap. solved that issue but still having problems with reverse light not coming on in reverse and no speedo. checked all possible fuses, everyone ok.
kindness
Aug 31, 2012 11:20 AM
Teamdiesel
Apr 26, 2009 03:43 PM
busyychild
May 6, 2008 11:09 AM
rtrsl
Dec 6, 2007 05:04 PM
1 sLoW hAtCh
Feb 20, 2007 11:00 PM
