*** IGNITION PROBLEM???? ************
Took the distributor off and cause a friend needed it to test it on their car. Once we re-installed it back it was fine for about the first 15 mins of driving. Once the car got hot it started to stutter. I had this exact stutter 3 months ago and I changed the plugs at that time and the car was fine until today. We marked the position of the distributor so I don't think timing is the issue or is it? It stutters at idel and under acceleration. Could plugs have gone bad that fast? Do I have to adjust timing using a gun after re-istalling the distributor? What stumps me the car drove fine for a little while and only started stuttering once it got warm.
Yeah - it drove fine for a little while but after it started to bog... I will try advancing the timing on the distributor a bit as a first step I guess. After that rotor and cap? Or ignitor? Not quite sure where to start....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">Have you checked for signs of leaking spark?</TD></TR></TABLE>
How is this done?
How is this done?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe »</TD></TR><TR><TD CLASS="quote">did it work on your friends car??
check your coil see if its burned, also check your cap and rotor...</TD></TR></TABLE>
Check the plug wires also.
changed the cap n rotor - car runs worse now!!! WTF????
also noticed some water around the 2nd cylinder plug - dried it up but car still stutters... Will try changing plugs today I guess and next step wires after that.
ok - checked all 4 plugs+wires and they seem to be ok...
when i set the timing to 16 deg. the car misfires a lot. Misfires seem to dissapear if I advance the distributor timing a lot (like almost all the way). This doesn't seem normal?? Could a bad ground have something to do with this?? I am stumped...
sounds like some one steamed cleaned the motor and got water in the plug wire ends i would check all of the wire ends at the cap also.
Check the plug wires also.</TD></TR></TABLE>
Change your wires for a test. Sounds like you have a plug wires that is bleeding the spark and grounding out on something.
Then give us an update.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by havok hybrid »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>Thread
whatcivic
Nov 5, 2007 03:19 PM
unLuckylude666
Apr 17, 2004 09:41 AM
