Timing Problem.. possibly??
Old Jan 11, 2003 | 04:32 PM
spike's Avatar
Default Timing Problem.. possibly??
Ok here's the problem. We've been putting together a turbo kit for the past year and we also needed a new distributor because it was busted up in the accident. The car has not been started in over a year. Now the car will not start, it turns over but does not sputter or anything. The distributor can be put in either one way or exactly 180 degrees the other way. We manually cranked the engine until cyl #1 was at the top. We then made sure that the distributor rotor was on the #1 spark plug and cranked. We have fuel and spark. Any ideas? Could we be 180 degrees out of wack? Why won't it start?!?!:? Please help, I've been troubleshooting all day. thanks!
spike's Avatar
Default Re: Timing Problem.. possibly?? (spike)
we also put an V-AFC in.. we are supposed to have IN and OUT both set to 06 correct? and throttle to 4 cyl / Up-Right arrow. thanks!
Old Jan 11, 2003 | 08:00 PM
IN VTEC's Avatar
Distributor keyway is asymmetrical. Only goes on one way. You'd really have to pound it in there for it go on the wrong way.
Make sure that the rotor position and crank position correspond. If cylinder #1 is at TDC, set the distributor so that the rotor faces towards the #1 cylinder firing position.....down, and facing towards the bottom (if you're looking from the passenger-side fenderwell). See other post in Tech for the pic of #1 rotor positioning...pretty recent posting.
Sensor # = 6 IN /6 OUT
Cylinder # = 4
Thr = going up
Old Jan 11, 2003 | 08:04 PM
IN VTEC's Avatar
Default Re: Timing Problem.. possibly?? (IN VTEC)
Check your harnesses on the distributor...maybe swap ignitor with the old one.
Old Jan 11, 2003 | 09:36 PM
spike's Avatar
that is exactly what we did.. set the crank so that #1 piston was up.. at TDC.. and rotor was at #1 also.. facing in the car direction.. still nothing
jdmtegrunner
Oct 14, 2009 06:34 AM
whatcivic
Nov 8, 2007 03:16 AM
javiergt02
15
Aug 21, 2006 07:37 PM
GQ Cowboy
May 17, 2003 07:10 PM
FitCRX
Feb 19, 2003 08:23 AM
