Just replaced the axle STILL CLICKS!!
Old Nov 4, 2007 | 08:51 PM
scobaru's Avatar
Default Just replaced the axle STILL CLICKS!!
Just did an axle on the integra on the driver side everythign went well but it still clicks!. the axle is a reman. and I'm starting to believe its a bad wheel bearing.
my friend Andrew's corolla would click when the wheels where turned and there was power being applyed much like the problem with the integra ((clicks only when ur on the gas))
Anyone else know what else it could be or would you say wheel bearing?
Old Nov 5, 2007 | 03:40 AM
Chiovnidca's Avatar
Default Re: Just replaced the axle STILL CLICKS!! (scobaru)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scobaru &raquo;</TD></TR><TR><TD CLASS="quote">((clicks only when ur on the gas))
Anyone else know what else it could be or would you say wheel bearing?</TD></TR></TABLE>
Do the wheels have to be turned? Or does it do it going straight? Never heard a wheel bearing make a clicking noise.
Old Nov 5, 2007 | 08:37 AM
dognutz's Avatar
Default Re: Just replaced the axle STILL CLICKS!! (Chiovnidca)
I have been given so many bad reman'd axles it's not even funny. I always check parts as best I can because they will give you the wrong stuff or broken stuff from time to time.
Old Nov 5, 2007 | 10:58 AM
scobaru's Avatar
the axle looked to be fine
and the wheels have to be turned towards the driver side. it doesn't click pointed towards the right
Old Nov 5, 2007 | 12:43 PM
B16B_coupe's Avatar
HRD PKR
Default Re: (scobaru)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scobaru &raquo;</TD></TR><TR><TD CLASS="quote">the axle looked to be fine
and the wheels have to be turned towards the driver side. it doesn't click pointed towards the right</TD></TR></TABLE>
of course the axle looked fine, you cant see the inside!! try another axle... it only does this when turning to the left.. is anything hitting something elsE?
Old Nov 5, 2007 | 01:38 PM
Chiovnidca's Avatar
Default Re: (B16B_coupe)
And you're sure the noise is coming from the left side?
Old Nov 5, 2007 | 07:29 PM
scobaru's Avatar
yes its very apparent its from the left. the passenger axle has been replaced too ((was replaced becaue of an accident))
I'll call up napa
Old Nov 5, 2007 | 09:10 PM
civicking99's Avatar
sounds like you got a bad axle...complain and tell them that you want a new one because you have went through so many remans that were junk and they should give it to you at no extra cost
Old Nov 5, 2007 | 09:13 PM
scobaru's Avatar
I think my friend has an LS knuckle that isn't in use that I'm going to try to use. if I install it and it still does it then well we know what it is, and if it doesn't then I guess we know what it is lol
L2ILL
Oct 22, 2012 01:38 PM
efsex
Jan 9, 2010 11:52 AM
HOODLOVER
Oct 26, 2008 07:24 AM
spets
Suspension & Brakes
Apr 5, 2008 05:31 PM
BOOSTED_JDM_DB8
Dec 26, 2007 12:15 PM
