Smoking
My problem is the car smokes at idle at Random times... You can drive for an hour and never see it smoke and then while at a stoplight it will smoke for 5-10 seconds.. And its definitely oil smoke not gas...
Im puzzled to what it is, maybe valve seals I dont know. Compression #s are very high...It's a 2002 with 97,xxx miles on it....
Any help on this would be much appreciated... Thanks chris
i dont smoke its bad for your health.
But umm sounds like early valve seal warning to me. Try a leakdown test. What are the compression numbers exactly???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2SLOW »</TD></TR><TR><TD CLASS="quote">227-228 on all 4</TD></TR></TABLE>
how many cranks?
fuel pump is off?
how many cranks?
fuel pump is off?
2-3 cranks fuel was on didnt pull the relay, but they were all within 1-2 psi of each other so thats not the problem....It just smokes like every other day not all the time. It could be guides and seals but i dont know....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2kdre »</TD></TR><TR><TD CLASS="quote">my friend had the same problem, compression was good, and it only smoked on start up and idle, it was the valve guides and seals.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2SLOW »</TD></TR><TR><TD CLASS="quote">2-3 cranks fuel was on didnt pull the relay, but they were all within 1-2 psi of each other so thats not the problem....It just smokes like every other day not all the time. It could be guides and seals but i dont know.... </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco »</TD></TR><TR><TD CLASS="quote">rings maybe?</TD></TR></TABLE>
Oil rings going bad it would do it all the time....
Oil rings going bad it would do it all the time....</TD></TR></TABLE>
Under load, yes.
Bad rings would also show up in the compression tests.
Under load, yes.
Mine smoked a little when I stopped at red lights and I used about a quart of oil every 3-5k miles. I bought some crank vents and it totally stopped both the oil burning and using.
https://honda-tech.com/zerothread?id=2069580
Redprelude98
30
Jul 21, 2009 01:21 PM
turbo95eg6
Jul 10, 2005 07:22 AM
ALLMOTOR18
Dec 27, 2003 07:54 AM
