Car smoking.. How can I tell if it's the valve seals or valve guides?
Ok, here is my situation..
My car smokes when at a stop only after decelerating down a hill..
It also smoke when I am revving my car at about 6000 RPM.. The smoke is bluish and just seems to float around my rear bumper..
Under hard acceleration, there isn't any noticable smoke..
What is it?
Thanks in advance..
What is it?
Thanks in advance..
Moderator
Re: Car smoking.. How can I tell if it's the valve seals or valve guides? (ALLMOTOR18)
do a compression test and a leak down....my guess it is the rings...
Re: Car smoking.. How can I tell if it's the valve seals or valve guides? (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">do a compression test and a leak down....my guess it is the rings...</TD></TR></TABLE>
I did a compression test and all cylinders were around 255-260 PSI... The motor runs very strong still, but the smoke bothers me...
Re: (fulldragcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fulldragcrx »</TD></TR><TR><TD CLASS="quote">dear lord 255 to 260 psi. uh... whats been done to this motor?</TD></TR></TABLE>
JDM ITR Pistons and 2 layer Headgasket.. No milling...
Just a little 1.8L motor.. Thats all...
Location: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Re: (ALLMOTOR18)
one way u can check to see if its the seals is to take off the intake manifold and look inside the ports..if u see oil excess oil sitting on the back of the valve near the seat area its the seals...worked for me.
