Code P0141 Help!
Old Nov 3, 2007 | 03:30 PM
dc2go's Avatar
Default Code P0141 Help!
i got this code and ckf but i believe i fixed the ckf by hacking the ecu..anyhow, this P0141 isnt a o2 replacement (searched) but wire malfunction...(i think)question is where? is there a tool to diagnose this? running p75 ecu obd2a if that helps.
Old Nov 3, 2007 | 05:34 PM
Chiovnidca's Avatar
Default Re: Code P0141 Help! (dc2go)
p0141 is usually caused by an open o2 sensor heater. A resistance check of the secondary o2 heater will verify it's the problem.
Old Nov 5, 2007 | 03:24 PM
dc2go's Avatar
should i have car running when its being tested? how do i set my meter? what # is it suppose to show? google didnt help much... im a n00b at this
Old Nov 5, 2007 | 03:38 PM
Chiovnidca's Avatar
Default Re: (dc2go)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2go &raquo;</TD></TR><TR><TD CLASS="quote">should i have car running when its being tested? how do i set my meter? what # is it suppose to show? google didnt help much... im a n00b at this </TD></TR></TABLE>
Doesn't need to be running. disconnect the sensor. Measure resistance between the two black wires on the sensor. Use the ohms setting, should be 10-40 ohms if I remember right.
Old Nov 14, 2007 | 01:05 PM
dc2go's Avatar
checked and 2nd o2 is fine ... new ecu maybe?
Old Nov 14, 2007 | 03:26 PM
Chiovnidca's Avatar
Default Re: (dc2go)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2go &raquo;</TD></TR><TR><TD CLASS="quote">checked and 2nd o2 is fine ... new ecu maybe? </TD></TR></TABLE>
A problem with a wire, connector, or pin would be my next suggestions to check. Do you have power and/or ground to the o2 heater?
Old Nov 15, 2007 | 01:46 PM
dc2go's Avatar
ground? isnt one of the black wire, ground?
going to check what you mentioned. pain in the ****! =\
Old Mar 28, 2010 | 11:17 PM
JDM lt's Avatar
TRIAL USER
i know im bringing post from the dead but i was wondering if you ever fixed it?
Old Mar 29, 2010 | 02:16 PM
cmyrex's Avatar
useally the heaters go out wit o2 sensors my experiance is just to change it
Old Mar 29, 2010 | 05:31 PM
JDM lt's Avatar
TRIAL USER
yeah, changed both o2 sensors today, and now its throwing p0135 code and p0141... o2 sensors are good, checked, tomorow picking up ecu... i need to pass emissions in 2 days... any help is apreciated, btw sorry op for stealing your thread lol
skylude3
11
Oct 10, 2008 04:58 PM
die_lawn
Apr 7, 2008 05:30 AM
iLOVEmyEMone
Dec 29, 2005 02:57 PM
draxxus07
Sep 29, 2005 11:35 AM
suckawillis
Dec 20, 2004 05:29 PM
