Cat swap to test pipe
Old Nov 3, 2007 | 02:27 PM
King V's Avatar
Default Cat swap to test pipe
Is there anything i can do to extinguish a CEL for the rear O2 sensor after swapping in a test pipe? Has cat efficiency code. I thought i saw on the Net of O2 sensor "foolers" that tell the ECU a cat is there somehow. Does it affect fuel trims by not having a cat? Or will I just have to live with the CEL?
Old Nov 4, 2007 | 01:43 PM
SikB's Avatar
Default Re: Cat swap to test pipe (King V)
You could try a spacer that raises the sensor up out of the main flow so it just gets a little. I don't think it is guarenteed to work though. It shouldn't change your mileage it is primarily there to make sure the cat is working. Another option would be to get a conversion harness and obd1 ecu unless you have echeck.
the rook
Oct 20, 2015 08:00 PM
o0oz
Oct 10, 2009 06:27 AM
Raven_Accord
Jul 23, 2007 03:54 PM
Sohc-Vtec
26
Jan 13, 2003 10:58 PM
integra2000
Jun 5, 2002 04:01 PM
