Compression test results: Still Smoking?
Old Nov 2, 2007 | 11:19 PM
95greenlude's Avatar
Default Compression test results: Still Smoking?
i've been noticing some white/blue smoke coming from the exhaust the past few days. it only smokes at Higher RPM (5-6,500). i did a compression test at the results are as follows.... 158-175-170-165. those numbers dont seem that bad. even though there is one lower one. my spark plugs were all uneven also. cylinder 1 seemed to be running fine, while all the others were white (which indicates a lean condition). i'm probably going to pick up some new Spark plugs just to be safe. any input on what could be smoking???
Old Nov 3, 2007 | 06:00 AM
mgags7's Avatar
Jared, the rings that make compression are separate from the rings that seal oil. So, you can still have good compression #s and be burning a bit of oil up there.
That 158 worries me, generally you want all of your cylinders within 10% of the average, and that one is a good bit low.
Is your car tuned?
Most of the time, when the car smokes at high rpm it is from bad oil rings.
Old Nov 3, 2007 | 08:59 AM
AndyD's Avatar
Default Re: Compression test results: Still Smoking? (95greenlude)
Compression results are a little concerning.
Right now, first thing I would suggest is running Engine Restore with all of your oil changes
Old Nov 3, 2007 | 02:30 PM
Default Re: (mgags7)
no my car is not tuned
Old Nov 3, 2007 | 02:44 PM
ECX's Avatar
ECX
* B A N N E D *
When I did my compression test a few weeks ago on my h23, I got ~220 across all four, but yet my car is a failure as far as oil is concerned. I think it could be my (sealing) rings as part of it.
Old Nov 3, 2007 | 03:22 PM
roller3804's Avatar
That 100 shot of nitrous has alot to do with the rings I think. Especially if your not tuned.
Old Nov 3, 2007 | 03:37 PM
mgags7's Avatar
Running untuned with some nitrous could really generate some extra heat...not good.
Old Nov 3, 2007 | 04:09 PM
lude98SH's Avatar
Try doing a leakdown test that will show the condition of everything more clearly.
Old Nov 3, 2007 | 04:21 PM
Default Re: (lude98SH)
^i plan on doing that....
gooblinn258
May 30, 2014 12:20 PM
doublezerohatch
Jul 1, 2013 08:03 AM
t0kyoStatus
35
Jun 28, 2008 11:58 AM
JDMtype Eg6
Jul 14, 2007 02:31 AM
hondaeg8
10
Jul 25, 2004 11:13 AM
