Resurfacing?
I found a video on Streetfire and it talks about how and why you should resurface the block. In the video they are re-surfacing a B18A and the man in the video said that it is important that you resurface the block after having it apart. Is this necessarily true?
I will provide a link to the video, I'm not sure if Im allowed to or not.
http://videos.streetfire.net/v...9.htm
if the motor has been heated up for a long period of time, over normal heat, yes the heat makes it warp jus like the head. if u resurface it then it will bump up ur compression slightly depending on how much u resurface it.
justYncredible
Jul 5, 2016 07:55 PM
