94 accord distributor leaks
Old Nov 1, 2007 | 09:30 AM
ForceXVII's Avatar
Default 94 accord distributor leaks
I've noticed some grease/dirt on the distributor's cap, does alt mean I need cap & seal? Plz let me know. Thanks
Old Nov 1, 2007 | 09:48 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: 94 accord distributor leaks (ForceXVII)
is it oily only on the bottom of the distributor housing/cap?
The distributor o-ring could be leaking. simple fix and cheap part.
Old Nov 1, 2007 | 10:26 AM
Honda-Master's Avatar
Default Re: 94 accord distributor leaks (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">is it oily only on the bottom of the distributor housing/cap?
The distributor o-ring could be leaking. simple fix and cheap part.</TD></TR></TABLE>
if it leaks internally inside the distributor you eed to replace the distr assembly you cannot get the inner shaft seal
if outside leak at bottom of distr yep like touring said cheap fix
Old Nov 1, 2007 | 06:53 PM
loup05's Avatar
Default Re: 94 accord distributor leaks (Honda-Master)
how would u kno if it is leaking internaly? im asking because i think i have a oil leak coming from the dizzy too.. its real wet under the distributer
Old Nov 1, 2007 | 10:09 PM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
Default Re: 94 accord distributor leaks (loup05)
if you have a napa auto parts near ya and your old
dist. is leaking oil bring it to napa and get yourself a rebuilt DIST. cost me 190 bucks from napa. they will also want your core. Also if I were you i would keep the ignitor from your
oem dist. thta **** cost 240 bucks from the dealer, napa does not check the core
Old Nov 2, 2007 | 04:34 AM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loup05 &raquo;</TD></TR><TR><TD CLASS="quote">how would u kno if it is leaking internaly? im asking because i think i have a oil leak coming from the dizzy too.. its real wet under the distributer </TD></TR></TABLE>
you would know because the inside of the distributor would have oil in it. If you have oil leaking and is on the bottom of the distributor cap/housing but the inside is dry then it's just the o-ring. If you are leaking oil and it's not only on the bottom of the distributor cap/housing but also inside the distributor then you'll need a new distributor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidcool1977 &raquo;</TD></TR><TR><TD CLASS="quote">Also if I were you i would keep the ignitor from your
well if the ignitor isn't included in the rebuilt unit from napa then I see no reason you would have to supply one with the core. You should only have to supply with the core what you are receiving in parts.
Old Nov 2, 2007 | 09:57 PM
loup05's Avatar
i took off the disnt cap andits dry in there.. u think i just need the oringfro the dist?
Old Nov 3, 2007 | 02:21 AM
FarinaMotorsports's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loup05 &raquo;</TD></TR><TR><TD CLASS="quote">i took off the disnt cap andits dry in there.. u think i just need the oringfro the dist?</TD></TR></TABLE>
In your first post you said you saw "some grease/dirt" on the cap. Is there any oil? If there's no oil it's just dirty, wipe it with a cloth and call it a day. You only need to replace the o-ring if there's oil on the bottom of the distributor or cap. BTW, you'll know if it's oil. It will be wet not grimy.
F22 Accord
Oct 28, 2010 07:28 AM
jchrm80
May 17, 2009 09:27 AM
Rhood
Jun 16, 2007 02:34 PM
sailor77
Feb 28, 2007 05:10 PM
FMIDRC Racer
16
Oct 23, 2003 02:49 PM
