Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Honda Accord: how replace internal seal distributor internal oil leak
Step by step instructions for do-it-yourself repairs.
Leaking oil from distributor cap
Can some one please let me know how to fix this problem on my 97 Accord; oil seems to be leaking from inside the distributor cap?
People have been telling it’s a gasket?
Re: Leaking oil from distributor cap
that I have seen there are only 2 gaskets when it comes to the distributor. one on the tip and the seal on the camshaft. Neither one that I have ever been able to see has to deal with fluids going into or out of the distributor. Take the cap off and look at the walls. But I am nearly 100% sure it is one of the 2 seals previously mentioned. I just did a major overhaul of my engine gaskets and they are the only ones there other than the cap gasket itself.
hey man I stand corrected. After checking out the threads I came across one that may solve your issue check it out and let me know.
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-internal-seal-distributor-internal-oil-leak-2214402/
H-T Order of Merit
no glue or anything is required to hold either the o-ring or the seal in place.
just to clarify...
you are leaking oil internally into the distributor? and are replacing the internal oil seal as well or just the external o-ring?
just to clarify...
